Securing unit
Funstini
Feb 24, 2009
63
I am setting up the truck bed tie downs for a Keystone. I don't have the camper here, I am getting it out of state. Are there any mesurments as to where to drill in the bed and place the eye bolts? Do I need to use a large support brackets (washers) under the bed so the eyebolds won't come through?
Also I have a 2002 Ford F-350 I'm thinking I will have to fir-up the truck bed floor. I was going to use pressure treated 2x4's, which would make it 3 1/2" taller. Sound like a good plan?
For the fronts I was told go 3" back from the front of the bed and 3" from the sides, there abouts. For the rears I was told to put the bolts in the range of straight down from the eye bolts to about 3" back from them (I went back a bit). Either get the guy to measure how far back from the front of the camper the eye bolts are or just pop them in when you get there. I had to move mine because they were a tad too far back and the camper was hitting them (measure that too before drilling). Yeah you want some large washers or a metal plate to sandwich the bed. I think some folks use fender washers but I used 2" square washers that are 1/4" thick. Eyebolts are 3/8" dia bolts with a 3/4"-1" dia hole.
If you've confirmed how much you need to raise it and 3.5" is what you need then I'd thick some pressure treated 2x4's making up a frame should be fine.
I'd just take my charged drill and a spare battery. No surprises when you get there...
3x3 steel, sandwich the bed.
Congrats on the camper.
Hay, thanks guys. Looking forward to hitting the road ............
If you want to do it right the first time, call our service dept.
Ask for Chicali
(800) 242-1442
As long as he knows the year of the camper, he can usually get you dialed in.
It will be worth the call if you want to save your self some time and hassles while you are on the road
I second that Stan I called Chicali and he was right on the numbers.
Hay thanks again .......... glad I found this forum, the information is great and I can tell you're all very passionate about it.
