Sharing the FWC and bedliner on a working truck
OK, your mission is to go to your local Tractor Supply Company (tell your wife you're on a "mission") and get those numbers.
Spend as much time there as you think is needed.
This message will self destruct in 5... 4... 3... 2...
I've used the ProGrip ones that Old Crow mentioned for tying down large objects. They come in a variety of sizes and work great. Fwiw most turnbuckles have lower ratings than even a small eye bolt.
Just a follow-up on this subject. I went with the ProGrip bolts from USA ProGrip Products (http://usaprogrip.com/products_detail.php?id=155). They're similar to the Quick-Ties mentioned by Alley-Kat. They went on easily and did the job exactly as I had wanted. Thanks all for your help.
How tight is the fit on the truck bed? How much room do you have between the camper the vertical edge of the bed?
