Shower Curtain Install Questions Swift
Dec 15, 2020
22
Hi all, I jus ordered a KickAss shower curtain.
My plan is to mount it directly to the driver side rear corner of my 2015 FWC Swift Shell model. From my understanding there is an aluminum beam near the top of the camper that I should be able to mount to with a couple bolts going through into the inside and large washers and seal it up. How far down from the top of the bottom section does the Aluminum beam run?
here's the shower curtain I bought
I got it mounted up. I ended up just mounting using 5 bolts drilling 5 holes through the swift upper section and using bolts and fender washers and nuts on the inside. turned out great!
How do you like it after some use?
