Side mount for small raft frame
robcc
Jan 29, 2021
57
Bayfield Colorado
Here is an "out of the box" design idea: We’re going to travel with our small cataraft in our camper. We want to avoid putting the 48 lb frame on the roof because it will be hard to raise and lower the roof for camping before and after a river trip and it is pain to take the frame on/off. Could we mount the frame in the photo onto the jacks mounts on the right side of the camper. The frame is 91” long with a 8-1/2” depth (so it would stick out 8-1/2” from the right side of the camper. Some of the frame would extend in the back of the camper. Would the brackets hold if I welded some sort of bracket? I’ve seen some people mounting surf boards on the side of campers and some people mount bikes on the side of camper shells. Would this be legal? Thanks
I did and they said "That’s the only place that would be strong enough and safe enough to secure it to". The frame is where the jacks attach.
I believe most states have a legal limit of 8’ 6”, so you would have to calculate your width. My guess is that any side mount approach will have the frame out another inch or two. Here’s a rack system that might be a starting point, second item down. My inclination would be to spend less than $100 for a speaker lift that would assist you with raising the roof.
Google site wanderthewest.com "speaker lift" for threads that show the lifts.
Edit: they’ve gone up in price at Guitar Center, now about $170.
if u travel without jacks, u might look into the 8020 camper side rack brkts from saltmade.co
I took the above recommendations and bought an 80/20 rack with brackets and vertical rails from saltmade.co
With the small cataraft frame on the vehicle it sticks out 10-3/4" from side of the truck with a total vehicle width of 7'-1/2". So it seems legal and solid. The only issue we'll have to loosen or lower the frame slightly to access the rear popup latch. We hope to carry SUPS and other stuff (not at the same time). We also got a speaker lift if we put things on the roof, so now we have options. IMG_4619.jpg
