Sliding window
wpage66
Mar 12, 2015
36
KS
First loading for spring and noticed I now have a sliding rear window on door.
Looking for away to fix. The benzel on the inside has screws so I guess I will start there. IMG_20190423_175759.jpegIMG_20190423_175832.jpeg
Oh no! I was just at an RV shop getting some sealant work done and while were looking at the door he asked if the window had ever slid down (like what you show). The RV guy mentioned that if the window had slid, the frame probably has "tabs" that hold the window in place, and that based on your pictures, your bottom tabs may have broke. He said that if that was the case, you may be able to take out the window + frame, flip over the frame (putting the top tabs on the bottom?), put the window back in and reseal.
*Note: never tried it, never seen it, have no idea if it would work, just overheard in a passing conversation. Try at your own risk. I would call the factory and ask what they recommend. They're very helpful!
I had to replace the window on my old 2000 FWC. It is very easy but I had to save the clear glass because most replacements I found didn't have the clear glass.
Kinda red neck, but ... Thinking about what I would do if this happened on a trip somewhere...
Just push the glass back up, and silicone around the edges to hold it in place? At least, until you find a replacement?
Knowing me I might try flip it over or make new tabs all the while applying lots of sealant. Would have a better idea after it was apart as to what route to take. Try a fix first before spending money on new.
Just thinking out loud but if the tabs aren't strong enough to support the weight of the window I would find something else that is. There might be room between the 'tabs' and the bottom of the cutout in the door..
Silicone sealant does not bond well to glass or aluminum and it's elastic enough to still allow the window to move around a bit.
Vic's idea sounds OK until you have to remove all that RTV in order to do a real fix. It doesn't bond well long term but always seems to when you want to remove it.
Another quick fix might be to use clear packaging tape to seal the gap until you get home. Some acetone will easily dissolve the glue left behind when you peel off the tape to do your repair.
Rant: It bugs me that the door glass is held in place this way. It should be glued or at least gasketed in place.
My door window got shattered on a trip (I subsequently learned from that trip to have a piece of Luan 3/16" cut the same size of glass...I store it under the mattress... hardly any weight and handy in a bad situation). I dismantled the door and installed new glass in the frame. there were tabs on mine but not much other than a groove to put sealant.... than the frame screws held it tight... has been fine since...5 years.
I put a piece of rigid foam insulation inside the window frame to support the glass when I rebuilt the door on my old camper. Duct tape was the field repair when I first noticed it slipping, on a dusty road of course. The foam was a much more elegant and permanent solution.
This happened to me years ago and I turned the frame upside down to utilize the unbroken tabs.Once assembled I ran a bead of silicone around the outside of the glass and frame.I guess you could silicone the inside also for extra support.
