Thanks for the comments guys! We'll I got a chance to did into the camper a bit this weekend. My goals were to mainly clean it up, build a base for it to sit on so it clears my cab a bit more, and to seal the outside.
Got her off the truck and ready for some work!
I then took all the cushions out of the camper and threw the covers in the wash for a good long wash cylce. The ended up cleaning up nicely. Guess the old retro brown will stay.
Here are a few shots of the inside all cleaned up.
Feeling good, it was about 6:00pm and time for a BBQ and some beers.
That night it bothered me about how dirty the thing still felt. The previous owner had defiantly used it well and didn't exactly keep it up to my standards. Since this is going to be a camper I plan on keeping for a while, I was up at 6:30am the next morning with coffee and tools in hand. Time to start the real stuff!!!! :elkgrin:
I disassembled the bench which is really basic btw and then tore out the old side carpet and flooring. MUCH BETTER!
The old staple construction was pretty taxed so I predrilled holes all over. Filled them with gorilla glue and screwed treated decks screws everywhere, especially some extras around the bolt/turnbuckles. Now Im feeling good.
Unfortunately, I found a bit of dryrot in the upper corners of the plywood. You can see it in the picts above. Ill have to dig it out and fiberglass resin the void.
Also, the front lift panel is pretty much done. I saw this when I bought it, but didnt realize how much work they are to fix. Put a call into Terry at FWC yesterday. I'm going to buy one the last few remaining wood panel kits. They run about $200. The new composite panel kits are over $400! YIKES! Glad they have a couple wood kits left.
Sorry for the fuzzy pict.
Next up was a simple platform. I built it out of 2x3 studs. It raised the camper up just enough. About 1-1/2" over the cab. Looks great and fits just right!!!
I plan on sealing and painting all the exposed wood on the exterior of the camper a bit later. Just ran out of time.
Going to be able to get a little time to keep rocking and rolling on it again this weekend. Plan is to get the fridge out and give it a good cleaning and servicing. I want to add a drawer right below the sink and above the fridge as there is enough room. I also plan on taking out all of the sliding doors and I think they are cheesy. Ill add regular cabinet doors at all those locations. We'll see how it goes!
