Solar Controller Clicking
robcc
Jan 29, 2021
57
Bayfield Colorado
We have a Renology Solar Controller. I've never noticed this before but it now seems to click a lot (every 10 seconds) especially in the morning and evening. My thought is this is when the sun is barely charging the system. Is this normal?
I wonder if the [SIZE=13.3333px]solar controller is cycling on and off from "full charge" to "maintain" mode or something.[/SIZE]
[SIZE=13.3333px]Be sure to check al connections. Maybe clean the terminals and all connections and see if that helps.
There are some Renogy trouble shooting videos on the web but i did not see anything specific to the clicking.[/SIZE]
Anything is possible.
Are you sure it is not your battery separator ?
That is the most common item I see on a regular basis that display those same symptoms.
(clicking every 10 or 20 seconds)
If that is what is actually clicking, charge up your camper batteries overnight with a portable battery charger, or through the camper IOTA power converter by plugging into 110/120V AC shore power.
See if that takes care of it ?
(sample picture attached)
I think Stan is right. And if he is, you might want to look at changing/upgrading the separator and/or the wiring between truck and camper. That clicking is preventing you from getting the truck to charge the camper batteries.
Follow up-- One of the wires was loose on the battery. A reminder that it is often the simplest solution. Should have checked it first.
