Solar Noob Q: [@Costco] Coleman 100w Panel integration
BigRanchInSky
Dec 31, 2018
45
Utah
Well, I'm itching to get my camping on, but staying put for now as per CDC guidelines, there's not much close by, I'd have to drive at least 1.5 hours away to camp right now=pretty cold in the Wasatch Mtns at present...the wife works in health care, so no go for me for now...so there's only one cure for that: Camper upgrades!
Today @ Costco they have a Coleman Solar panel on sale, $129 with free shipping, and I'm wondering how it could be integrated with the 2019 FWC Hawk. See the attached JPEG of the unit.
Since I'm a noob, of course I'd love to just plug the thing into the standard FWC solar extension plug (I believe my solar plug is on the rear of the camper) and away it goes...is there something I need to do before I plug it in? Keep the supplied controller or loose it? I have a 160 Watt system with 2x12V batteries, all stock from FWC as of 2019. I can probably handle finding the right plug adapter and hopefully get the polarity correctly identified when hooking up the plug leads, any info on that appreciated also.
Thank you in advance, I appreciate your ideas!
Your solar plug on the rear of the camper should be wired directly to your solar controller. Therefore, your portable panel should not have a built in controller and you shouldn't use a portable panel with one. Our 2014 Grandby had 100W Zamp on the roof, with a Zamp controller. When I purchased a portable 80W Zamp panel, I had discussions with Zamp and FWC and they both confirmed the portable panel should not have a controller.
Thanks Longhorn! OK, so take away the controller and get the plug figured out and I should be ready to go, correct? I purchased online, so it won't be here for a few days (hopefully not weeks) and I'll go from there.
Q: Are all solar plugs standard or will I be needing to get a unique plug somewhere?
The solar plugs are not standard. FWC uses an SAE plug. You will need to buy a pigtail and splice it onto the wires coming from the solar panel. You can use a multimeter to measure the polarity of the plug on the side of the camper.
It sounds like you have already ordered this, but if not, a foldable panel is a lot easier to deal with in the limited storage of a truck camper.
I'm a solar noob too. Just a thought, if a portable panel had it own controller; would it not be feasible to rewire the rear plug so that it goes directly to the house battery? You would then have two separate controllers charging the battery independently. Should be Ok? I had also read somewhere on this forum that if a single controller has multiple solar panels connected that they should be identical?
I don't think the controller cares where the power comes from. They are designed to take an input of some amount say 19.6 V and output 13 v or 14 v, as long as you do not exceed the voltage or current input limits of the controller. However, mixing panels may be less efficient than if they were all the same make and model.
https://solarpanelsvenue.com/mixing-solar-panels/
On the other end however it is best if all the batteries being charged are the same.
yes, that works too. You will really want to have a battery monitor with a shunt, like the Victron BMV 712, to keep tabs on the battery SOC, especially with two chargers since neither charger will be "aware" of what the other one is doing.
Wow, such great info, thank you!
RE the size of the Coleman panel: ouch it IS big, and heavy @17 lbs vs the foldable one @6 lbs for the one linked above...so I'm thinking it was a rash purchase and I might need to return it to Costco. Drat. Oh, well, better now than after I get it all unwrapped, etc.
And adding a shunt with Victron 712 sounds like an excellent idea, but I'm going to have to research like mad as to how and where to add that. Looks like the Victron unit come with a shunt according to this video:
Now I'm re-thinking if I can handle this...(I can't). I've actually never run out of power with the supplied 160 watt solar, I was thinking more=better. It may be time to simply ask if it's a good idea to go to all the trouble to add another set of components to the 160w system.
If anything I'm even more impressed every day with the components and build quality of the Hawk: it's really worth every penny, although it would've been nice to have a Victron controller installed, but they can't have every single available option in their builds.
Adding the Victron unit would be great but even that is way above my ultra novice level.
I think I'll shut this down before I waste anyone else's time. I'm glad I waded out into the stream and found it hip deep before I tried to drive through it, alone.
Returning the Costco panel before you would need to modify it and kicking this down the road is likely a wise choice. I really doubt you would end up using it much.
