Replaced furnace board *** New items were done in 2015 New vinyl (2015) New push boards (2015) New propane tank, valve Jack brackets (no jacks) New sail swith New jet in furnace Cleaned flume Installed refrig fan and heat sensor New refrig gasket New uphostery New cushion (memory foam) on bed Updated flooring and underseat wood Digital thermostat High end Dometic/Fantastic Fan w/ remote Sliding front window All high grade turnbuckles and eye bolts Backing plates on top and bottom of camper and truck BlueSeas isolator Extra usb and 12v outlets installed in camper CO detector installed Illuminated rocker panel with switches inside of camper Quick connectors for wiring installed Sealed roof, seam sealed interior Vinyl plank flooring and updated bottom bed frame New style storm flaps (included) Installed backup (OEM) camera Custom made HD steps (removalable bottom step and handrail). Bad Battery (AGM) not holding charge; will need a new battery Front Passenger side wheel guards (scraped but touched up with touch up paint) I used seam sealer on window seams (inside)
