coulter6
** SOLD **
This camper was custom built specifically built for a 2005+ Toyota Tacoma Access Cab pickups so the tailgate can be fully closed. I've had it mounted on a 2006 Tacoma Double Cab with a 5' bed.
Total width is 75". The part that sits in the truck bed is about 70.5" long and 41.5" wide.
Dry weight: ~ 785lbs; Wet weight: ~ 1000lbs.
Fits most small trucks such has the Dodge Dakota, Ford Ranger, Chevy Colorado, etc. It will also fit most full size pickups.
Like new; still has that new camper smell. You won't find another camper this nice unless you buy a new one. Only a hand full of nights total camping in it. Everything is in excellent condition.
It's fully insulated and has full vinyl flooring, welded pro-flex frame, fiberglass siding, large exit window, privacy curtains, 12v ceiling lights.
- Queen size bed with huge under-the-bed storage
- Escape hatch. Skylight (26"x26") above the bed
- 3 cu ft 3-way refrigerator
- 2 burner stove
- Large single basin sink
- Dinette that makes into a second bed
- 4 corner jacks (manually operated, but drill bit to raise and lower the roof included). 2" extender brackets added to front jacks
- Back door system includes a safety handle mechanism (locking), screen door, and awning
- Electric roof vent (separate from skylight)
- 85w Solar panel with controller
- 110v system
- 12v Battery system with 85amp battery
- Front slide opening window to allow truck-camper pass-through
- Furnace (10,000-12,000 BTU)
- Water Pump
- 15 gal water tank
- 20 gal Propane tank
Also available at full purchase price:
- Torklift front and rear frame mounted tie-downs. Front tie-downs # T2303. Rear tie-downs # T3303. Fits year: 2005-12 Model: TACOMA (4WD ONLY) Bed Length: ALL
- Firestone Ride Rite Air Bags #2407
REDUCED to $12,500
below NADA
Located in Albuquerque, NM
505 two seven four 1211
buck dot coulter@comcast dot net
- 2 burner stove
- 110v system
- Water Pump
- 15 gal water tank
REDUCED to $12,500
below NADA
