*SOLD* Outfitter Manufacturing Caribou Lite for Mid-size
alphabetadog
Jan 10, 2019
9
Prescott, Arizona
2016 Outfitter Manufacturing Caribou Lite 6.5 for Mid-Size pickup
Excellent condition, located in Prescott AZ I absolutely love this camper as it is extremely practical, reliable, and easy to use, but I have decided to buy a cabin cruiser boat to explore the Puget Sound and Gulf Islands and my wife says the camper must go.
6.5’ bed length, 3.8 CF Tundra refrigerator, 100 watt Go Power Solar system w/ controller and converter, LED lights, 27 series house battery, 1600 BTU furnace w/ thermostat, 3 burner stove, Fan-Tastic power roof vent plus add’l standard vent, sink w/ electric pump & 20 gallon water tank, 8’ Fiamma awning, dinette, and flip-top vanity.
Camper is in excellent shape and in perfect working order. A few minor scuffs, but no deep scratches or dents. Mounted on my 2005 Toyota Tacoma and all Torklift tie-downs included.
Description of standard features
• Fully welded aluminum frame
• Torsion assisted lift system
• Vacuum bonded composite walls
• LamiLux High Gloss 4000, high gloss, UV protected, white exterior (non Luan backed)
• Owens Corning® block foam insulation
• Solar reflective windows
• Weblon Insulated Softwall (3 Layers Std.)
• Electronic ignition 16K BTU furnace
• 4 corner mechanical jacks
• 20lb LPG bottle with gauge
• Power Roof Vent system
• 24 gallon fresh water supply
• Shurflo® electric water pump
• 3 burner high-output stove with Piezo ignition
• 45 AMP PD converter with 3 stage charge wizard
• Full size cab-over bed, pulls out to queen
• LPG & Carbon monoxide detectors
• Pressure fresh water fill
• 110 outlet
• Birch interior doors and cabinets
• Washable curtains
• Sliding cab through window
• Camper anchor tie downs, centering guide, and turnbuckles
• Screen door and keyed locking deadbolt
• Camper dry weight 850 lbs.
New well over $19k and at least a 3 month wait. Will sell for $15,000. Call or email, but no texts. Steve: 480-215-1310
That's a really nice little camper, Steve! Sounds like an awesome reason to sell. :)
Travel safely,
Kevin
Travel safely,
Kevin
Thanks Kevin! Yes, I've really going to miss it. Indeed it is a great camper, we've had some good times together. Going to buy a C-Dory boat that has a cabin about the size of this popped up with similar features, so it should be similar but floating on the water!
I'm getting lots of calls and emails on this camper, but mostly by those with full-size trucks. This specific camper is for a mid-size like my Tacoma, but could be adapted to work with a full size truck by building a 4" platform to raise the base so the overhangs clear the side rails of the bed. The cab overhang isn't a factor as it is built the same for both a mid and full size truck.
It's still available, but probably not for long!
If you haven’t found the CBrats, it’s a good resource for the CDory crowd.
Latest posts
