Denver Alaskan
- Joined
- Sep 27, 2013
- Messages
- 83
I am ready to reintroduce the factory dinette table into my 1966 8 foot Non-Cab Over (NCO) Alaskan camper. Here is the dinette table in dining position:
When I had that area converted into a bed, the bottom seat cushions (with their plywood bottoms) were pulled together and rested on 3 slats that bridged the open area underneath those seat cushions. Here are the slats installed:
When that area is converted into a bed, the dinette table will have to be stored somewhere. I hoped to lower it and have it rest between the two seat bases on either side, but the table is narrower than the two wood strips on either side that the slats rested on and it falls between them, as seen here:
My first question is: why didn't Alaskan make the dinette table wide enough to rest on the two wood strips on either side of the open floor area? Were they worried a large guy might sit on the bed and break the supporting dinette table in half?
Most campers are built so the dinette table can be lowered to rest on the seat bases and bridge the open floor area while supporting the cushion bed.
There are two ways to solve my problem. First, I could remove to two thin wood strips from the seat bases and replace them with wider ones that extend far enough into the open foot area to support the table on both sides. By doing this I could eliminate the slats. This is a simple direct approach, assuming the table is thick enough to handle my 180 lb. weight when sitting on the bed.
Second, I could add wider wood strips below the existing thinner wood strips so the table could be stored on the wider strips. I would then then place the slats on the thinner wood upper strips just above the top of the table so only the slats would support the bottom cushions for a bed. This more involved approach would duplicate the pre-table set up of only the slats supporting the bottom cushions while providing for table storage just underneath the slats.
My concern is understanding why Alaskan avoided the first direct approach back in 1966? Any ideas why?
Finally, does anyone have a better storage solution for the dinette table when that area is converted into a bed?
