Oly Bill
To quickly clean a standard two burner propane stove in your RV - remove the two screws near the burners. Then lift off the stainless steel stove top. Clean the exposed stove bottom if necessary.
To easily facilitate your next cleaning job - PERMANENTLY remove the two "pinch-like" small clamps that hold the grill in place above the two propane burners. Then install the stainless steel stove top w/the two screws. The stove grill will held in place by the two holes in the stainless steel stove top.
The grill can now be easily remove for an quick cleaning around the two burners after they have cooled. The grill should remain safely in place unless you "roll" your RV or get involved in a serious collision.
