I have a Swift Shell on order and wanted to know the exact interior measurement of the:
Drivers Side Rear cut away space near the rear door.
This space typically holds the propane tanks/batteries and is boxed in if you order that option.
.....As you walk towards the door from the bed area...in the back right corner.
My Shell will have this space without any wooden box/door.
I believe the below measurements are correct, but can anyone confirm? The Fleet might have the same dimensions.
1) Turns 7" outward towards the Right Wall
2) Turns Left 24" towards the Rear Wall (might also be only 17"???)
3) Leaving a 15" space between the cut way and rear door.
