Truckfridge Chest Refrigerator Repair TF51
ski3pin
Belay On
Site Team
RV LIFE Pro
Jun 30, 2009
15,701
Sierra Nevada Range
[SIZE=18pt]We had problems on the last trip. Setting up camp the first night, we found the fridge running with 37° showing on the display. It did not shut off after a time and the display still read 37°. I put our outdoor sensor for our indoor/outdoor thermometer in the fridge. It read 32°. Looked like the compressor/cooling was okay but the controls were at fault. We continued on the trip watching the temperature and manually turning the fridge on and off as needed. Interesting note is that every time we turned the fridge on, the temperature on the display would read 2° colder than the prior turn on. But as before, the temperature on the display would not change while running.[/SIZE]
[SIZE=18pt]After returning home, I called the Truckfridge support phone number and described the issue to the tech. His diagnosis was the thermistor needed to be replaced. He would send one out to me with directions for remove and replace. $23 total cost. It arrived here five days later.[/SIZE]
[SIZE=18pt]
[/SIZE]
[SIZE=18pt]Here is the process. The cover for the compressor area - 11 screws - is removed.[/SIZE]
[SIZE=18pt]
[/SIZE]
[SIZE=18pt]No need to remove any electrical connections to the power inputs on the cover. You can move the cover aside as needed.[/SIZE]
[SIZE=18pt]
[/SIZE]
[SIZE=18pt]You need to access the control board on the left side - two screws through the condenser coils - and remove the left side brace for access to get to the control board.[/SIZE]
[SIZE=18pt]
[/SIZE]
[SIZE=18pt]
[/SIZE]
[SIZE=18pt]
[/SIZE]
[SIZE=18pt]The temperature sensor on the thermistor is inserted into the fridge box via a tube that is covered with black putty in the above photos. Additional photos to follow.[/SIZE]
[SIZE=18pt]The control board is removed just enough to allow access to the thermistor connection. This makes it easy.[/SIZE]
[SIZE=18pt]
[/SIZE]
[SIZE=18pt]
[/SIZE]
[SIZE=18pt]
[/SIZE]
[SIZE=18pt]The putty on the sensor tube and the wire clip are removed.[/SIZE]
[SIZE=18pt]
[/SIZE]
[SIZE=18pt]
[/SIZE]
[SIZE=18pt]Removed the old thermistor. Here is old and new.[/SIZE]
[SIZE=18pt]
[/SIZE]
[SIZE=18pt]I connected the thermistor to the control board, reattached the control board, and reattached the brace.[/SIZE]
[SIZE=18pt]
[/SIZE]
[SIZE=18pt]I slid the sensor all the way in, replaced the black putty over the hole, and ran the wire under the retaining clip.[/SIZE]
[SIZE=18pt]
[/SIZE]
[SIZE=18pt]
[/SIZE]
[SIZE=18pt]I blew the dust out with my air compressor and reassembled. It appears to work! The display read 54° when I turned the fridge on and the compressor started up. It took only few minutes to bring the temp down - the display showed the lowering temperatures - and the fridge turned off at the set point.[/SIZE]
[SIZE=18pt]The repair took 15 minutes.[/SIZE]
[SIZE=18pt]I'll run it for a couple days to confirm the repair and then put it back in the camper.[/SIZE]
[SIZE=18pt]I hope this will be helpful to other WTW members.[/SIZE]
Thanks Ski- I'll keep this filed away in case I run into the same issue with my Truckfridge!
Thanks Ronin! I should add this refrigerator is a little over two years old. It has been put to use. :)
billharr said:
Sounds like great service from TF.
Absolutely! Especially in comparison to a couple of years ago. I called about figuring out a problem and the response was only ship it back, we can take a look at it. It now appears that they are helpful about common problems and have parts with instructions available. This is good news for us.
Also, they answer the phone with, "Indel B North America."
ski3pin said:
Thanks all for the kind comments!
The fridge passed the trial runs and is now back in the camper.
Where should we go?
Ski thanks for your review of the repair... easy peasy, done!
Weather is good.. throw darts to a map? You always surprise us!
