Turnbuckle Question
dharte
Dec 8, 2015
161
Hi Folks,
I was wondering if anyone has used a thread locker compound such as Loctite "Blue" (medium strength) formula to help keep the turnbuckles from loosening? Mine always come loose during/after every trip and I constantly have to check and tighten them. I am using the procedure of hand tightening and then 1/2 to 1 turn using a screw driver for leverage.. I can't see any harm in trying Loctite but I wanted to double check.
thanks,
David
I've gone a different route, I have stopped mine from becoming loose by using zip ties. I could never get two hands in that little cubby door to get a lock or jam nut tight enough to hold them. Once you get them tight you're just pretty much keeping the turnbuckle from spinning, no spin, no loosen. Ron
I doubt Locktite will harm the turnbuckle. You should probably call the factory in Northern Ca. for the best answer. I bet they will have a solution you could share with others on the forum who may be experiencing a similar issue.
I'm wondering if the loose turnbuckle syndrome is cause by something other than the turnbuckles unscrewing. The two other possibilities are the turnbuckle hooks bending under stress or the camper moving in the bed when the truck goes over bumps.
I was lucky to get explicit instructions from FWC where to place the eyebolts in my truck bed for the used Hawk I bought. Basically, the eyebolts are places so the front eyebolts pull the camper forward and outboard; the rear eyebolts pull the camper rearward and outboard. I'm thinking that this eyebolt placement has contributed to the fact my factory eyebolts don't loosen.
A couple of other considerations: In spite of my efforts to position the camper in the bed as far forward as possible, there's usually an inch or so of space between the front bed wall and the rubber bumpers on the front of the Hawk. And I have a thick rubber bed mat the camper sits on. The mat may or may not keep the camper from slipping around in the bed. The mat causes a bit of a hassle when I take the camper off because it sticks a bit to the bottom of the camper. But it seems to help insulate the floor in winter and the bottom of the camper looks almost as new as it was in 2009.
Hope this helps.
Ed
Somebody needs way too much time on their hands to do a study. Use cameras at each turnbuckle and do some off road driving and see how they move around. ;) :oops: :eek:
Thanks for the feedback. I did have the camper installed at the factory, and the forward turnbuckles pull forward and the rears rearward. I also have a rubber mat under the camper. I am going to try the thread lock and will report back if it works effectively. Ron, I'm curious how you attached the zip ties.
I put nuts on the normal thread portion of the turnbuckle and after the turnbuckles are tightened and set up I tighten the nights to keep the turnbuckles from moving.....it works and I haven't had any loosen up....
Just a NOTE / WARNING as I lost a turnbuckle that came off. Luckily I found it next time I removed camper it had slid under edge. I was on trip when I discovered it was lost. I check a lot but this was an excessive washboard trip and it came loose and off. So I stopped at the next Ace Hardware to get a replacement.The only one they had that was correct size had a looped screw on one end. No issue just bought a snap ring and used on camper end.
Now the warning... completed the trip... more washboards. Checked nightly and looked good. When home I actually removed camper. That replacement turnbuckle had actually straightened out on the end on bed eyebolt. Did not come off but was now 90 degrees and could have easily pulled off.
I was lucky I found the original :) But I went out and bought another forged turnbuckle as spare. If you replace your turnbuckles make sure you buy good one!!! I now have lock nuts on each and it seems to be working well :)
Hi David
Locktite will do no harm.
Also, you can buy forged turnbuckles at most any good hardware store that will not bend.
It might be a good idea to climb under your truck and inspect how the eye bolts are doing....tight install ? and no bending/distortion of the bed...were some sort of backing plates used?
I am not trying to alarm you but it is worth getting familiar with the mounting setup in the comfort of your driveway .
I don't know what truck you have.
Few truck beds are made for the kind of force the turnbuckles (and the camper bouncing around) can exert.
David Graves
I'm curious also about the zip ties.
I've also upgraded to 3/8" forged turnbuckles. Just run the ziptie through the turnbuckle and catch one of the eye ends, then it cannot spin. I also was having mine loosen up on wash board roads, tried several different lock nuts. But like I said, you cannot get your hands in there to properly jam them tight. No problem now with the zipties. Ron
I had mine installed at a dealer, they said the FWC recommends Loctite. Mine did not have Loctite and one came loose in the first week. If you are worried about blue being too hard to loosen try Loctite 222 (purple). It is meant to resist vibration. I have used in on bicycle wheels (spokes) for years and it has been great and allows for adjustment.
Here's a pic so you can see how simple. Ron
DavidGraves said:
Hi David
David Graves
Great advice.
I use a simple locknut on one side of each turnbuckle. It's not fun to tighten them down but they work great and will not loosen.
Blue lock-Tite will help. But in this application it's no replacement for a Locknut.
This is the right answer. I did this to mine after my install. I drove about 50 miles on paved roads and checked them. One was off the others were loose.
Good idea! The only issue I see with using a zip-tie, even a good one in black, is sunlight and/or will eventually kill them. I'd expect an annual checking of them would be prudent.
I did similar, only used Safety Wire which is 302 Stainless Steel and is intended for this use, but good ole fashioned baling wire would work.
There is absolutely no sunlight that hits them, they are in the dark. Also good quality zipties. And for those that say the lock nuts work and don't loosen, get off road on a wash board road, I have and they will loosen. Ron
