agate
I had a small problem with my pressurized water system yesterday. It seems that the valve connected to the clear plastic clean out hose on my 2009 Hawk's system sprung a leak on the backside and slowly dripped a couple three gallons into the cabinet and floor soaking the cushions etc.... sort of sucked, but not the worst.
We discussd the pressure system a bit and discovered that we both seem to turn it on a bit different. I crack the faucet a bit open then hit the pressure switch. My wife just hits the switch. Would either of these ways of operation have an affect n this leaky valve? It looks like a cheap $5 valve so maybe it is just time.
Also, the leaky valve has two different hose/pipe clamps. The one side the clear clean out hose is connected to the valve with a pipe clamp that works with a screw driver, pretty straight forward for a guy like me! The other side is crimped type thing, never saw this type of hose/pipe clamp before. How do I get that off?
This should be a fairly straight forward issue to solve.............Sorry for no pics, the camera is charging.
