Victron Shunt after update
buckland
Site Team
Jul 26, 2011
3,103
New England
I haven't used the carper for a six months. I have 200Ah BB batteries 160 W panel on roof. Every thing is running when turned on when I climbed in yesterday. Victron app indicated I needed updates on the Victron controller and Shunt (the DC DC victron charger was off as truck was not running).
I downloaded the updates and restarted the apps. All was fine on the Controller app but the Shunt Output read 13.43 Volts But the State of Charge was blank. Never saw this before I don't think. Here is a screen shot.
Voltage & current can be directly measured, but SOC likely requires cycling through either empty or full first to be sure that the software has experienced either charging/discharging endpoint, as state is probably not preserved through a firmware update.
Thanks so much Paul... I sure hope so as the whole system has behaved flawlessly since install... One of those "hope I didn't do something bad" moments ... I'll put some things on for awhile to bring down battery a bit and then see what happens.
Much obliged
Rob
Much obliged
Rob
I would suggest using whatever suitable charging sources you have to fully charge the batteries. Then check the battery capacity settings in your shunt app to make sure they still are set as you prefer, then hit the synchronize button in the app to set the state of charge to 100%.
Thanks Jon and Vic ... i do have a "Battery Tender" charger which says it has auto LiFePo4 charge ability. Is it ok to leave the batteries in place (they are in Parallel ) and simply attach charger to one and leave it on for a few days or until the indicator light goes green for full charge?
I was going to simply turn off the main switch. Nothing going out so should be ok.
OK.... can you keep in the sun too? a good two days of sun/mppt controller plus the tender should get you more than enough AH to be sure the batteries are full.
Well huh. Strange things are amiss. Put the charger on ....said it was charging ... a couple hours later I checked and the charger said done/full. Victron app solar said 14V ...Victron shunt said 14V but SOC was blank. I popped up and checked the lights, fridge turned on and was running fine. Then I tried the exhaust fan and it did not turn on. (it has been running fine all last year... a few years ago I had installed the variable speed circuit board which is/was great.... I bought 2 so have a spare).
So both batteries are fine apparently but the shunt still has no SOC reading at the top. Any thoughts on this conundrum?
Did you go into the app for the shunt and hit the SYNCHRONIZE button?
Remember the shunt and the hardware/app don’t actually sense the state of charge. They just measure the net current in and out of the battery and integrate it over time to give you a state of charge relative to an arbitrary starting point. The SYNCHRONIZE button sets the state of charge reading to 100 percent as that starting point when you press it, and the integrator tracks it from there. You can set the integrator to reset to 100 percent automatically when charging voltage and current reach specific levels, or you can just manually hit synchronize every once in a while, like at the beginning of each trip if you know your batteries are fully charged. I have mine automatically synchronizing.
Regarding your fan not working …
Some posters here have reported that their Maxxaire fan control board did not work after being subjected to the higher charging voltage of lithium systems. I have not had a problem, but I have my max charging voltage limited to 14.2 vdc. Some people have theirs set as high as 14.6 vdc. It’s possible this caused your fan failure. I’d start by checking the fuse, though, and making sure the fan is free to turn.
Thanks for your ideas. I just went out again and checked and in the Shunt app in the gear settings there is a "reset state of charge" button.... should I first reset this before synchronizing?
I assumed the app for the shunt looks the same as the app for my BMV-712. Here’s what my battery settings screen looks like. I don’t have a “reset state of charge” line item.F1D14D6D-C375-4BC8-8025-6D5C3DE8F8FA.png
Can you post a screen shot of your battery settings screen?
I will get out there this morning and try the suggestions and take a screen shot. I too have the charge set to 14.2 and the fan has been running for years on lithium. I'll check if it is stuck or the fuse too. Thanks again. It is really the first time I have had any trouble with the system .... And this happened just while the camper was on the truck but not being camped in (New England winters).
Thanks again for your insights.
Below is the reset I mentioned. It will 'go into effect' after synchronization which I have not done yet. I thought I'd wait as it is a very sunny day..... so later this evening I will sync.
Update!!! Gremlins be gone! They say you don't know what you have until It's gone... nope.... I am eternality grateful for folks here on WTW. I have a place to ask questions and get help.... where else would I go!!??
Got out there and pulled the fuses ...as the list on cover did not mention fan I pecked around. Think there was oxidation on one or two as now the fan works fine!! I decided to synchronize at 13.7V as I was wanting to see if the SOC number came back and lo and behold there she am! So all is now well in River City!
Appreciate help from you all. Now I can worry about something else!
Happy Spring
Rob
I'd keep it as it is.... that way it should reset itself when it gets to 100%.
FWIW, I have run my BB's down to flat twice too, also because the SOC reading was way off. In at least one case, it was because I had attached something to the wrong side of the shunt, which might be what Bigfoot Dave is asking about above.
However, you haven't changed any wiring recently, have you?
Edit: OK, just saw your update, and the problem you reported is gone. I'm not sure what you found? Stuck contacts? Fan running continuously? Synchronization had NOT been done in a long time.... please clarify.
Also, when your batteries were dead and SOC read 100%, did you happen to notice the voltage reading? Mine read 5.xV when "dead" or sleeping.
Batteries weren't down they were full. No wiring change as I haven't used camper in 6 months. Fan didn't turn on. Now it does as I think fuse had oxidation. So batteries were never dead and fan works. All A-Okay now!! Appreciate the help.
