buckland
That's the exact one I found but my original is 6"x6.5" and this one isa bit wider (1") ...I wonder if the cutout is the same or iff not I can cut a bit more. When you did yours is there aluminum frame in the wall there?
The only other question is the configuration difference in that currently just the fat one hose from tank (minus the breather) and now there will be two different diameter hoses needing to go into the single tank hose. Anyone know a source of a "Y" fitting with two different diameter male ends?
