backcountry
Hi All,
I recently discovered this forum - looks like a good place.
I'm in the process of resurrecting a FWC for an International Scout. In addition to replacing a lot of parts, I have converted the unit into a slide in camper so it can be more easily removed and installed. I'm using it on the longer wheelbase Scout Terra pickup and it fits almost perfect.
I am trying to determine the best material for waterproofing the exterior slide in portion of my Four Wheel Camper. The bottom sides of my camper are made with ACX plywood. What do you suggest I use as a protective coating?
Your help is greatly appreciated
Here is a photo of my work in progress:
