Anyone know of a good weather sealing product to use around the inside of the door? Mine has foam on it but its wearing thin and i would like to replace it. Thanks all!
ben, thanks for getting back...i was actually referring to the inside of the door frame...just the metal area where the actual door fits into when its closed...mine has some foam tape around the door frame to provide a seal and that is what is coming off...i'll post a pic later today after work! thanks again
just took a quick photo to show what i am talking about...not a big deal. i am sure i can find this stuff anywhere i just thought someone might have an inside tip!
You should be able to find that seal at Home Depot or a store like them. Look in the Door Department for door seal foam and you should be able to match it up with what is on the door now. I have done that myself in the past.
