What is the Kestrel model?
A hawk built to fit the Toyota tundra. Edit: fit it better, I forget the exact on whether they adjust the cab over height or if its in the side wall height but that should get you in the right direction.
The Kestrel Model is the Hawk Model is all ways, shape, and form.
The Kestrel Model is just what we call it here (for the most part) when we are building a Hawk Model for an older Access Cab Tundra.
Unless you have a 2000 - 2006 Toyota Tundra Access Cab truck, ther would be no need for the Kestrel Model.
We generally build the Hawk Model to fit all of the short bed trucks on the market (Dodge, Ford, Chevy, Toyota, Nissan Titan, etc.).
The Dodge, Ford, Chevy, & Double Cab Tundra trucks have a bed depth of approx. 20” (20” deep from the floor of truck bed to the edge of the bed rails on the truck), and some even deeper.
The 2000 – 2006 Toyota Tundra Access cab trucks are sort of an odd ball truck in the fact that it has a shallower truck bed – approx. 17” deep from the floor of truck bed to the edge of the bed rails on the truck.
If we put the regular built Hawk Model on the Access Cab Tundra, the camper will look like it is sitting a little tall on the truck.
(there will be a large gap between the edge of the camper and the bed rails of the truck, and the cab-over on the camper will be sitting taller over the top of your truck cab).
Some of the newer trucks coming out in the past few years are all a bit different, so we need to adjust some of the campers accordingly to better fit. There is no extra charge for this. It is just something we want to do here at the factory so the campers look the best. We really want the campers to be light weight, low profile, and durable.
See attached pics.
Just let us know if you have any other questions.
We would be gald to help.
Happy Camping !
Ok.
I was a bit confused as, I've seen it named on the website but, not really under products.
I have an 03 Dodge 2500 and I think the Grandby is for me. I saw a listing for a used one that Said Grandby(kestrel) so, I'm sure sure the person knows what they have.
I plan to see you at the show this weekend and take up a lot of your time. So much of your time...I'm already feeling bad about it.
Thanks,
Bryan
Rather than start a new thread regarding Hawk/Kestrel differences, I thought I would revive this one. Note that there is a similar one here: <LINK>
My questions are :
1) Given the 3" difference in side wall height, how does this impact the interior cabinet sizes/storage space?
2) Is the cloth top 3" taller to give the same overall inside standing height?
3) Is the rear door 3" shorter on the Kestrel, meaning that in/egress will involve that much more bending?
4) Does the Kestrel come with both short and extended cab-over lengths?
5) What is the thickness of the cabover section when folded up... 8" or 10"? Or both depending on the year made?
Can't think of anything else to ask right now, but if you have owned both a Kestrel and a Hawk (BillHarr?), it would be good to hear from you here.
Thanks!
My 06' Kestrel is 18' side wall size as best fits gen one Tundra. My Truck is a gen two Tundra with 22.2 side rails. Therefore had to fit a 5" platform to raise the camper to 3/4" above cap rails. Door height seems same as std Hawk interior as well.
Sent from my iPhone using Wander The Western city of
Here is Stan's response to an email I sent him
Hello Vic
Thanks for the e-mail.
Yes to all of your questions regarding the Kestrel Model.
Floor pack is 3" shallower -- make the camper a better fit on the 2000 - 2006 Toyota Tundra Access Cab.
Rear camper doors is just a little shorter on some models.
Side walls of the campers are the same. The only difference would be the camper base depth.
Pop-up material and pop-up height is the same.
Inside height is probably 6' 3" -- instead of 6' 6" like a Hawk.
You lose a few inches of floor storage space on the Kestrel.
Hope this helps.
Stan Kennedy
Four Wheel Campers
109 Pioneer Avenue
Woodland, CA 95776
1-800-242-1442 or 530-666-1442
http://www.fourwheelcampers.com
stan@fourwh.com
Additionally, bottom of cab section of camper to top of Tundra is 5 1/2", folding pop up top is 10".
