What to look for on a used Grandby
Rob~
Sep 29, 2010
11
Hardy Creek, Mt.
Hello, I just bought a 1998 Grandby and found this forum while doing some searches. I found a lot of info, nice site. I don't have much experience with campers My neighbor used to let me borrow his older Jayco pop-up for hunting season. I like it so I bought this unit off my step-dad, he rarely used it. Am I correct in my thinking that the heater and lights only operate off 12VDC and the 120VAC shore power operates the fridge and electrical outlet by the sink? I was just going through it for the first time today and haven't picked up a battery yet. What throws me a bit is my neighbors unit would run the lights and heater blower off the battery or 120AC supplied by my generator. The heater is an Atwood 8516, I found a manual on the Atwood site so I'm pretty sure it's 12VDC only but I've been known to be wrong, often according to my wife. I'm also curious about the fabric on the pop-up, is it PVC like a raft? If so I imagine one would do repairs the same? It's in good shape, but just in case and to be prepared. Any other advice on what to do maintenance wise is welcomed. Thanks for your patience, newbie questions can be repetitive. I picked this up for $2000 and it came with an earlier model Whitworth 7x57 with a simliar vintage Weaver V7, both new, the action still in cosomoline. I think I did well\relative discount ? Thanks again, Rob.
Apparently, you did well with the rifle. I think a Whitworth 7X57 is a rare gun. Post pictures of the rifle and ammo. That alone might be worth 2 grand.
Will the camper fit your truck? This is a serious question. Get out your tape measure. This may be the real stumbling block.
The electrical part of a Grandby is relatively simple and they have been well engineered. But git rid of that generator because you will need the rifle in good working order if you camp near me with a generator. The campers who populate this forum will not want to camp around anyone with a generator! You should figure out how to wire your truck and whether or not your Grandby is set up for a "house" battery. Welcome to the forum. John D
Yeah sounds like you got a good deal.
The side liner material can be repaired like vinyl, although I think the actual material is a little better than that. Its recommended to clean/protect it with 303 aerospace cleaner every 6-12mo for optimal life: http://www.303products.com/shop303/index.cfm/category/65/303-aerospace-protectant.cfm
I have a 99' hawk so I'm guessing you're electrical system is basically the same. Heater is 12V only. Fridge should be a 3way that runs on propane, 12V, or 120V (bear in mind on 12V it better be running off a running vehicle or it'll kill a battery quickly). The 120V plug on the outside of the camper feeds into the breaker box and then feeds two (2) outlets, one on the counter and one behind the fridge which the fridge is plugged into. There is not any convertor/charger to provide 12V power from a 120V connection.
I added batteries into the camper and do not run the camper off the truck battery (I do have a charger from the truck to the camper batteries but that only will run when I have the truck on, so again I can't ever drain the truck battery via the camper). I also added a 120V to 12V charger to my camper such that when I plug the camper into 120V it automatically starts charging/floating the batteries to keep them topped off as I use things in the camper that utilize 12V power. FYI: I run my fridge 99% of the time on propane mode with a pilot light reignitor to make sure it doesn't blow out.
I just bought a 1993 Grandby a month ago and had almost all the same questions.
The 12v and 120v systems are totally separate in our vintage campers. As had been said the easiest way to upgrade this is to add a battery and then add a charger/maintiner to the mix - so in the situations where you have a plug in you can recharge/maintain your battery. The high dollar option is to wire in a converter/battery charger combo like they have on the newer models... IOTA 30
As for what else to look for - check the sealant on the top screws, clean out the furnace and fridge buners and lines, check the tie downs for pulling through.
After that if all the appliances work - you are good to go!
Thanks for the info. I do understand the sentiments on generators. However, a good one like a Yamaha or Honda placed in a good spot is so quiet I've never had a complaint when using it with my wall tent. I have a cpap machine so AC power is a must for me. I plan on installing two batteries and I can use it to charge them as well. I have been think of making a converter to run the cpap off my batteries. It does fit my truck, I hauled it home. I'm going to make a stand for it on casters so I can keep it in the garage.
John, I'm not sure how rare the gun is. It has the Whitworth Stamp on the top and side of the receiver but the stock looks like a typical Interarms stock. I'll have to research it a bit.
A small inverter can run this of batteries easily, they don't pull much juice. Some also have a 12V direct connection option.
I'd lean towards that and then if you need to charge up your batteries on a long trip fire up the generator for a bit rather than all night.
I'll look into that. Does anybody make an inverter that doesn't have the plug on the end but rather some leads for a battery connection?
I just finished up a dolly for the camper to sit on so I can roll it in and out of the garage. Next step make sure everything works. I have twenty straight days off this hunting season. I can't wait. I am on call 24/7 to fix digital billboards but odds are I should be ok.
They might but what I'd do is just make up (or buy) a little adapter which would be the female cigarette lighter connection and clamps for the battery on the other. That way you'd still be able to use the inverter inside the truck cab to charge cell phones, etc. if you wanted.
I thought the larger ones all had a heavier duty direct to battery connection. The plugs can be a weak link. Chop the plug and put the connectors you want on the wires. I actually have three inverters, one I think 1500w in the camper direct lead to the house batteries, one under the hood with a direct lead to the batteries and an extention that goes through my grill so I can charge our Segway when on the road, and the third which I didn't bother with this last trip is inside the cab using the cig lighter. Maybe I need another, somewhere??
Keep in mind he only needs one of the smaller ones to power the CPAP, that is why I'd just leave it alone so it could still be used in the cig lighter to charge up things, etc.
