Nimbl Vehicles
Gandalf the Grey
You asked, I listen, here it is.
The XP V2
An all composite (what else) pop up camper for the Tacoma. Can also be built as a slide-in version.
An all composite camper, no wood frame, no welded frame and no staples. Sound familiar? Same quality construction and equipment as on the XPCamper, this little brother has it all for the domestic outback traveler.
It even features an inside shower and cassette toilet!
Features:
All Composite construction
Seamless composite roof
Outside storage compartment
Fiberglass countertop
Composite storage system
SMEV 3 burner cooktop with integrated sink, foldable faucet and glass lid
Electric Water Pump from Shurflo
Danfoss compressor removable refrigerator (44 quart)
o This new refrigerator features the best of electronic control technology. Highly efficient Danfoss compressor, energy saving function (ECO), turbo function (MAX) and multifunction electronic thermostat allow an easy and economic management of the fridge through a check and a reduction of power consumption. Operates on DC12-24 Volt and AC 115-230 Volt, 50 and 60 Hz. The switching between DC and AC is automatic. Three battery protection levels are standard.
110V System w/ Power Converter
Interior LED lights
12V Porch Light
20lbs Propane Tank
Fire extinguisher
25 Gallon fresh water tank (can be heated with heater option)
Water gauge
Standard queen bed (option @ $ 425.00 European spring mattress system)
Under bed storage
Dining table (converts to bed)
Dinette seating with Sunbrella fabrics and high quality foam
Under seat storage
Dual pane windows with privacy shades and mosquito netting
Safety Exit
Electric roof vent reversible
Heki sky hatch with privacy shades and mosquito netting (option @ $ 745.00)
Insulated XPTent walls with large windows and quadruple insulated coverings
Ducted hot air heater (option @ 1200.00)
Hot water heater
Cassette toilet (option @ $450.00)
Interior Shower set up
Outside shower
Build in access steps on entry door
150 amp AGM battery from Lifeline
Marine breaker panel and wiring through out
3 x 12 v outlets
125 Watt Solar panel with charger (option @ $895.00)
Fiamma awning (option @ $625.00)
$18775.00
For a limited time we will offer the XP V2 Outback model which includes ALL of the above options at a
Special intro price for $ 19995.00
The XP V2
Features:
Interior LED lights
12V Porch Light
20lbs Propane Tank
Fire extinguisher
Water gauge
Under bed storage
Under seat storage
Safety Exit
Hot water heater
Outside shower
3 x 12 v outlets
$18775.00
