Yakima Roof Track Sealant
marblecreek
Mar 12, 2010
10
Today I decided to try out my factory installed Yakima roof tracks on the camper. In order to install the mounting hardware for the cross bars (landing pads) I need to remove the end caps on the tracks. The hitch is that the end caps are screwed into the roof and sealed with a bead of caulk. Nothing is every easy!
I am looking for suggestions as to the type of caulk that I should use when I put things back together. The caulk that they used at the factory is a natural rubber color and very flexible. Thanks.
Steve
Use a Marine type sealant. Try a local boat supply or West Marine, Boater's World.
Marine grade stuff is made to withstand all the elements.
Thanks!
I use this:
3m 08019
Color - Clear. High quality silicone designed for the harsh marine environment. It forms a mildew-resistant, non-yellowing seal that remains flexible even after years of exposure.
