richardstover said:
I have a 2015 Tacoma DCLB with a FWC Fleet. Tires are heavy duty and one size larger than stock. I am a little concerned about wear and tear on drive train over time and am considering regearing lower. Has anyone done this? Regearing is expensive. The expense argues for not regearing, but better performance and durability may argue in favor. I just don't know.
Hey Richard,
I have a 2015 DCLB with a fleet as well. Mine is supercharged and I'm running 255/86r16 (33") e rated tires. I DID feel the need to re-gear. Or at least the desire. Especially after monitoring transmission temps driving around town in the summer with the camper. I like the truck but am not overly impressed with transmission performance. Clearly from the factory they are geared for economy as much as possible, and I believe they all came with 3.73 gears. Overdrive is pretty tall. If you can actually maintain overdrive with the torque converter locked, economy should be decent. I live in Forest Grove, and you know the Oregon speed limits and hills, the transmission was always hunting.
Unfortunately the transmission goes from overdrive with torque converter locked, to simply unlocking the torque converter when more power is required. The slipping torque converter increases temps very quickly. Performance is much better if you put the transmission in drive and allow the torque converter to lock, especially when climbing hills. Transmission temps stay much lower.
Anyway, I did re-gear my Tacoma. Mostly for performance and also to reduce the strain on the transmission. I installed 4.56 gears, which combined with 33" tires is geared a bit lower than stock. Roughly 200rpm higher than a stock Tacoma at 65-70mph. The drivability is WAY better. Climbing mountain passes is effortless. The transmission doesnt hunt so much, moves quickly through the gears, and transmission temps are much lower from light to light in town.
Fuel mileage suffered a bit, as expected. It isn't bad if I'm actually driving 55-60mph, but if I need to put some miles behind me and I'm cruising at 80mph down the freeway, up the passes etc it isn't uncommon to see 12-13mpg. No surprise here considering the drag, higher RPM and supercharger. I'm not one to happily hold up traffic over the passes, and the setup really performs well.
In your case, you have a little tougher decision. 4.56 gears would probably be a little short if you're only running 31-32" tires, depending how fast you drive. 4.10 gears would be closer to factory but it is SUCH a small change from 3.73 gears that it would barely be noticeable. Just expensive.
I used east coast gear supply. I bought a third member and front clamshell diff, both loaded with 4.56 gears and ARB lockers and a CKMA12 compressor. After shipping and receiving the core charge back, I think I was out $3100 or $3200, plus my labor.
If you have any other questions feel free to email me as I don't login here often. I'd offer to let you drive my truck but the camper is currently back at the factory.
Brian
choppedair@gmail.com
