Removing the extra 3" of floor pack on a Hawk
EDR
Jan 12, 2015
177
SE WA
I have an '07 Hawk I picked up last year. I learned through this site that I own a Hawk designed for another truck, with 3" added to the floor to fit over the side rails/cab of certain trucks.
Having seen other trucks with "normal" fitting Hawks, I was thinking I may try and remove the extra flooring to bring it down to the normal height.
Has anyone remove the added flooring from a Hawk?
If not, does anyone have knowledge as to how the extra flooring is built or monted on my style Hawk?
Wuck,
Thanks for the link.
It looks like it should be fairly simple to remove.
I sent DirtyDog a message to see if he removed the false bottom on his Hawk, and if he had anything to add.
Thanks again.
Ah, DirtyDog left us a while back. He founded Wander The West but has since sold it and moved on. Marty at ATC could probably give you a good tutorial on removing your spacer.
