maxcustody
- Joined
- Nov 3, 2018
- Messages
- 22
I need to replace my original batteries from 2017. 2-6 volt Centennial CB6-224AH. 2017 Hallmark Guanella. A couple of questions and thoughts............
First, I am very lucky nothing bad happened, I pulled the camper off the truck and was going to put the battery tender on and found this....................... They were so swelled up that I had to use a pry bar to separate them to remove them from the battery box.
Not sure if they got overcharged or what. We do not use the camper very often and it is stored in our shop which is not climate controlled. Would keeping it plugged into an outlet overcharge this much?
Also, we have a new 2024 F250 and need to use an extension cord due to the 7-pin location in the new truck. This would not do damage like this to the batteries, would it?
As for the replacement, I was thinking of doing one lithium battery, however, my inverter from the 2017 PD4045KV does not have the switch to run lithium, being a 2017 model.
I want to find smaller batteries (footprint) due to the size of the battery box but not having any luck. After research, it states that new batteries should be replaced with the same AH, which, in my case, is 224. So another question is why are others replacing them with much less stated AH if this is the case?
I could update my inverter but don't want to get into rewiring everything.
Any help, suggestions, and information is greatly appreciated.
Thanks, Scott
Thanks, Scott
