10 ply. Tire Recommendations
Recycledon
Apr 7, 2022
5
Hello folks! Extremely new here and wanted to ask about upgrading the tires on my 2013 Nissan Pro-4x to an E rated; 10 ply tire. I've added airbags, leaf springs and rear shocks to upgrade the suspension on the truck to handle the added weight ~1,1200 lbs. I'm now shopping for a 10ply tire for my truck that currently runs a 265/75 R16 size tire. I want this tire to be rated for driving in the snow, but I want it to also be a year around tire that's not studded. Any Suggestions on a specific brand that you like would be great!
Sincerely,
Donny Addison
Eugene, OR
BFG K02 has never let me down. You'll find lots of people on here who swear by them, myself included.
I've driven them in every type of terrain and they're great. Low road noise, long life, and fantastic in the snow!
Donny, first… welcome to WTW,
I’m a fan of Cooper Discoverer AT3 tires, about 5 years back, an evaluation of top brands was performed by the good folks on Expedition Portal. The Discoverer was rated best all around. Depending on your load, I’m not certain you need an E rated tire. A conversation with a good tire shop might be a good move. The heavier tire does impact your mileage. Just my 2¢.
Careful with those critiques. What works good on one vehicle may not work well one another. Ex. My Jeep loves the BFG MT's. My truck not so much. I do like the Coopers but this year I'm trying out the Falken AT's and so far I'd rate them comparable to the Coopers.
The best deal I've found locally is the Auttro Trailblazer. Any thoughts on that tire?
I'm going to keep running my current tires for the next month or two. Still in good shape and we don't plan on doing any major off road driving for a bit. Mostly driving on highways and forest roads.
Thanks for the input everyone. I will post of pics of our setup soon!
Donny
I run E rated tires just for extra bit of load and protection. Have used Michelin AT2 (another friend with Tundra and Cougar pulling a trailer has used these for over 500,000 miles on three trucks with no issues). Currently running Coppers on a 21 tundra with camper (only 4K miles so far) and have Les Schwab Mazama's on the 05 Tundra with a camper. Have also used Toyos and KO2. The KO2s were definitely noisier than others in our experience. The Michelin tires definitely got the most miles wear wise.
I've run both Falken Wildpeaks and Toyo A/T IIIs. Both are good. Nothing is as good in the snow as a dedicated snow like a Nokian Hakkapeliitta though. It's not worth changing anymore though.
Dean's comment is spot on.
We have a 1993 Dodge W250 and Michelin LTX and Defender LTX tires for years. Recently I switched to Michelin Agilis CrossClimate. 3 peak rated. I estimate our driving is 90% on pavement of some kind mostly dry buy also wet and snow (not always smooth) and 10% off pavement of which less than 5% is rough 4WD track.
I also tried 235 width and find 215/85 work best on my truck.
The new Michelin's are holding up well so far - they were put on new before our 82 day Alaska/Canada trip last summer,
P.S. I forgot to add that I have always gotten at least 60,000 miles out of these tires and typically closer to 70,000 before the wear bars are even with the tread.
I was pleasantly surprised that mileage in our KO2 (different from KO, not sure how much) was about the same as our P-rated tires. The E-rated tires were 50 lbs (37 for the P-rated tires, so they were 36% higher), and unsprung weight is supposed to affect mileage. Perhaps the much higher pressures made up for that. We run the KO2s at 47/62 (front/rear), and the P-rated tires were at 35/35.
We are averaging 18 mpg, but drive slower than most people on the freeway. Eyes on rear view mirror -- trying not to hold up traffic!
If your not doing heavy off roading. Michelin LTXs performed well on my 2WD Tundra, can't tell you anything about performance in snow and I do not recommend them in mud as the clog instantly. I'm running Cooper ATPs on my F250 4X4 now and I'm very pleased with them as an all around tire.
I have used the Michelin LTX, Cooper Discoverer AT3 and the BFG KO2.
Michelins.. got 37 k out of them, so so in the snow..
Coopers .. got about 40k out of the them, terrible in the snow..
BFG .. Current, now have 15k on them, still look practically new. The best of the 3 in the snow.
I feel the the BFG are the quietest of the bunch surprisingly, but the others were not bad. MPG is about the same with all tires.
I would say whatever you can find a deal on would be worth it, but so far I am partial to the BFG, will kind of depend on how many miles I get out of them..
Howdy
This is probably common knowledge but I believe the BFG KO2 tires are sold both with and without the winter use "snowflake" rating.
They certainly are surprisingly quiet and smooth on the highway for such a tread profile.
David Graves
Yes, comments on performance depending on the intended vehicle is spot on. Despite my experience with them on a heavier truck, I think the KO2s would be a good choice for your set-up.
KO2's here. I was almost convinced to try some coopers, but they don't make my size in the "XLT" variety, so when I get new tires soon... Sticking w/ the KO2's.
(Cooper Discoverer LT's have less aggressive tread.. XLT's are the offroad ones)
DavidGraves said:
Howdy
David Graves
Agree with you on that.. I expected a louder tire for as aggressive the tread profile is.. but.. its not..
Your best tire will depend on all of your demands. Here's my brief review of the General Grabber ATx
Pro
Quiet, great snow rating (a hair better in reviews than the ever-popular K02), inexpensive, even looks good (it's a copy of the K02 from tread design)
Con
When pressured high (which you can do with e-rated tires) I have been unimpressed by its traction on wide well graded gravel roads.
What I mean here is, compared to my subaru, it feels like it fishtails more.
We're happy with the tire. It's tough and grips well over rocks and big features. It's been fine in the snow, although, again, the subaru is better. It's remarkably quiet (I would have thought all-terrains were noisy and I understand some are). But, and I'm new to this, I kinda expected subaru-like traction on my truck, which may be asking too much!
Hope this helps.
3rd set of Yokohama Geolandar’s for me. Great on snow and ice, did really well in Utah again this spring, very quiet on the highway too.
