12 volt fan for Eagle
elduderino
Feb 29, 2012
17
Can anybody suggest a good 12 volt fan for night operation that does not draw too much energy?
Thanks!
You mean for cooling -- creating an indoor breeze on a warm night?
I've used a computer case fan for miscellaneous air-circulation needs...they work well if you don't need a lot of air blowing around (less than 100 cfm, usually). Quiet and efficient -- and cheap.
Here's a link to some 120mm-diameter choices at Newegg.com: Computer Case Fans (120mm)
A typical current draw is 0.3 - 0.5 amps (at 12 volts) for this size/type of fan. There are also bigger ones available.
I bought one of these for a trip to southern Baja one summer. It got us thru some sticky nights on the east cape. No idea how efficient it is but it got the job done. I use it for the dog sometimes when driving in the heat..
http://www.walmart.com/ip/Schumacher-Fan/13005737
I haven't tried one of these, but I plan to get one this summer. It's a Fantastic Fan in a box fan frame.
http://www.amazon.com/Fan-Tastic-Vent-01100WH-Endless-Breeze/dp/B0000AY2Z6/ref=sr_1_1?ie=UTF8&qid=1333121703&sr=8-1
Here is a better price, just happened to see it.
http://www.campingworld.com/shopping/item/fan-tastic-endless-breeze-12v-fan/38132
