19-21 Toyota Tundra Dbl Cab?
penner
Feb 2, 2017
191
For those of you with this yr Tundra , is it possible to just remove either the 1/3 or 2/3 section of the rear seat? Also, I see the antenna is rear centre of the cab. Do you re-locate it? Thanks.
The entire rear seat comes out as one piece in my 2019 double cab. Which I did to create a platform with underneath storage. Did not move the antenna.
Thanks AWG. Once the seat is removed is there any kind of "sound deadening " left behind it? My Chev seat is a pain to remove and then I have to line the back with a kind of insulation or it's way too noisy.
There is a thin floor covering in the back, which I left in place. Honestly, after I built the platform, I did not notice any sound issues. The sound muffling likely increases when we load up all our stuff before a trip.
I have a '19 Double cab and was able to remove just the 2/3 seat out when I first purchased the truck. On my Tundra there is a bracket between the seats that each seat bolts onto independent of each other. The 1/3 seat remained fully functional but after 2 years of never using it I decided to pull it off as well.
