1977 FWC Fleet Complete Overhaul
I have a contrary thought about the strategy of making our campers "bombproof". One of the things I like about them is that they stand up well to time/abuse, and can be diss/reassembled. Hence I used NO glue when I re-built my camper(s).
Maybe of combo of approaches is best, making somethings that never should have to come apart more bombproof than other parts?
I've been talking strictly about the floorpack, not the cabinets (someone else mentioned cabinets). For the cabinets yes allowing for disassembly/changes is a wise approach, you don't want those one piece all glued together permanently imho.
For the floorpack I don't want it rotting and I don't want it coming apart. I've seen rotting and coming apart in multiple older campers, usually starting with the edges of the plywood wicking in water/rotting/taking damage which is why I want those edges sealed up well.
That all makes sense to me - I think for the interior we want everything as modular and reworkable as possible. I guess the floorpack is more permanent though.
Well we finally got some plywood - I did end up using baltic birch since Front Range Lumber didn't have any 1/2" or 5/8" marine grade. They only had 5/8" baltic birch in 5'x5' sheets, so I went with my hybrid thickness plan and bought 1/2" for the vertical surfaces and 3/4" for the horizontal ones. We cut about a third of the panels out tonight with help from my dad, while my sister cleaned up the frame and pulled out the remaining staples.
What do people typically do to seal up the plywood? I was going to use spar varnish, but I wonder if some kind of epoxy would be longer-lasting. @pods8 I've been thinking more about your fiberglassing idea... maybe coating the whole thing in a good West System epoxy and embedding glass cloth just around the joints is the way to really do it right?
I just used spar varnish, 3 coats and double on the edges. It shouldn't be getting wet inside.
My build is modular but each module is made to not come apart. It has withstood 8 years of offroad pounding.
I did a lot of alternate designs in SolidWorks before I started building and the setup has worked well enough to not want to change very much. I did rebuild my refrigerator housing when I replaced my fridge but I wouldn't have used the old cabinet parts anyway (went thinner and lighter).
The original ones were just coated in a single part paint, originally oil based iirc. If you want to go that route the homedepot in Arvada carries glidden floor and porch gloss polyurethane OIL based which is decent esp. in our climate but I'd consider that a bare minimum. The other stores in the area didn't have it when I bought some for a different project recently.
There are magnitudes to doing it better and where you feel you want to step off the overkill train (esp. in the CO climate). ;)
-IMHO since we aren't in a production environment skim coating it in epoxy seems a wise and easy move because it'll soak into the wood fibers bonding them together better against damage and water intrusion. Other than some cost its not difficult to paint epoxy onto a surface and let it soak in, you'll need to scuff sand it once cured to prepare for painting afterwards.
-Adding some glass cloth over the joints would be an upgrade and help those more prone areas hold up better (you'll need to put a smaller fillet on the inside corners with thickened epoxy to get the glass to lay into those). This doesn't add too much difficulty.
-Doing a thin layer of glass over the whole thing would be best to really add a layer over all the wood fibers to resist against the wood checking and add further waterproofing. This part is more time consuming and finicky.
You will still have to paint for UV protection. A bedliner material (esp. a two part one) would be a great tough coating over it all imho.
Yes west system is a major brand. System 3 and some others are out there too like uscomposites.
He is talking about rebuilding the floorpack, not the cabinets (yet), it will absolutely get wet on the exterior.
@JaSAn that's just what I am going for - I hope to be able to push this thing pretty hard off road! I haven't even gotten beyond the daydreaming stage as far as interior layouts go, though. I hope to also keep it light and simple... We're used to tent camping so the goal with this build is nothing more than a structure I can stand up in with a furnace and some lighting for winter use.
Pods - I really appreciate the advice here, you clearly have some great experience with fiberglass and the different matrix systems! I was trying to brush up on all that after work this week; I worked with composites a bunch on college but that was like a decade ago now haha. I think I'll order a kit of MAS epoxy from Chesapeake Light Craft to do the bulk of the sealing. I also ordered threaded inserts for the aluminum and a bunch of hex head 8-32s...
I'm hoping to be able to create a stronger connection between the upper frame and plywood structure with these inserts... they mount with tiny 2-56 self tapping sheet metal screws... This is probably overthinking things, but I didn't like the weight of everything in the camper riding on .0625" aluminum "threads".
I have most of the plywood cut, and the plan is:
1) Assemble the plywood panels to the frame temporarily with clamps, and glue/screw the plywood joints together... Currently thinking I'll do each side seperately and install the floor last.
2) Pilot-drill the locations for the threaded inserts through the plywood and into the aluminum frame (to guarantee they will line up)
3) Remove the wood structure and install the threaded inserts in the frame
4) With each plywood assembly seperated from the frame, seal them up with the MAS epoxy - possibly add some glass tape to the joints (haven't decided on this yet)
5) Final install the plywood subassemblies to the frame and seal up the two joints between the floor and side subassemblies with epoxy.
I've built up both sides of the floorpack, with just the bottom floor to cut out still:
The plan is to assemble the floor in three parts, the right/left sides and bottom. We assembled the plywood with Gorilla Glue and wood screws every 6"... the pieces line up so that the screws are always going through the 1/2" pieces and into the 3/4" ones in an effort to reduce the risk of splits. I also predrilled all the holes and ran the screws in before the glue cured. The wood was all clamped to the frame while we were putting it together, so hopefully the finished product should fit nice and tight!
The left side of the aluminum frame has the threaded inserts installed, and the plywood subassembly is bolted to the frame through them using 2" long 8-32 hex head screws:
Each one of the inserts has #2 self tapping screws to keep it from spinning:
I also put huge washers on the screws (on the wood side) to distribute the load some. There are about 30 bolt/insert pairs on the left side of the camper (not counting the "bottom" floor), so I'm hoping this setup will make for a stronger joint than the original had!
After getting all the plywood assembled, I unbolted the left side as a subassembly to prepare it for epoxy:
We added some more glue fillets and enlarged the bolt holes some, to hopefully make it easier to find those inserts again after the plywood gets epoxied. In the morning I'm planning to sand it all and radius the outside edges so the glass cloth can conform to them better.
We intentionally haven't installed the threaded inserts to the right side of the camper yet - my fear is that the epoxy and fiberglass will warp the plywood subassembly just enough to make it tough to realign the holes with the inserts. I couldn't decide if it would be better to install them before or after fiberglassing, so I figured I'd try it one one side first. If it's a nightmare I know to switch the order of operations on the other side!
I'm terrified to apply the fiberglass and epoxy - scared to ruin the good work we've done! We have several yards of lightweight 4oz cloth to work with and MAS low-viscosity epoxy. I sprung for the kit that includes the metering pumps, mixing cups, rollers and spreaders so hopefully that makes things easier. We'll try to coat the outside of the subassembly, let that cure and then fip it to repeat on the inside. I am still wondering if the fiberglass itself is really worth it, vs. just coating the plywood in epoxy. I bought it, so I'll try to include it on this side at least!
What speed hardener do you have, I passed on doing a layup this weekend to finish glassing my floor pack due to the temps, I just didn't want to race the setup time with the elevated temps speeding it up. If you're worried work in smaller sections.
Glass probably is overkill as I mentioned before but I have it so I chose to do it.
I have the slow hardener from MAS and it has been just about right for the summertime temps in Bailey! Progress has been slow, but it's turning out pretty well I think. I put a 4oz layer of fiberglass on either side of each joint on the plywood subassemblies using an epoxy spreader squeegee, added a coat over that with a foam roller, and then sanded lightly before adding one more light coat of epoxy. The cure time between each layer meant I could really only get one thing done per evening, but both sides of the camper are all fiberglassed and sealed now! The last thing to do is install the main floor and do one more layer of fiberglass on the interior of the joints where it connects to the side walls.
I'm satisfied that my threaded insert approach seems to be working, and that everything lined back up after the fiberglassing steps!
It isn't aestetically perfect, since I didn't try to make the fiberglass layer continuous across the whole part... The joints are nicely covered but you can see where the fiberglass itself ends partway across the plywood panels (the whole thing is sealed with epoxy). This doesn't really bother me, since most of the interior will be covered up by flooring or the cabinets anyway, but is something to keep in mind if anybody else goes this route. It would have probably been smarter to get strips of fiberglass tape that you could stick to the joints prior to epoxy coating. Then the edges of the fabric would look more intentional at least!
Bailey, since you just recently disassembled your Fleet I'm sure you can answer my simple question. In one of your first posts you said that the missing/broken front tube was about .050". Do you know if the roof ribs are the same size and are they directly under the headliner trim pieces? I need to know so I can install a push board across the ceiling to help raising the front of the roof. Really don't need to be polking holes in it. I plan to install 30lb gas struts and maybe even get a speaker stand. Recently hurt my 78 year old back so it needs all of the help it can get.
Thanks, Dan
The roof is also made of 1x1" square tubing, but with slightly higher wall thickness of 1/16". And yep, they were right under the little trim pieces that secure the headliner! Here is what the structure looks like:
I haven't gotten much done lately since we've been taking advantage of summer and actually camping! Today I looked at the roof some more. The outermost square tubes were a little bent, I think from the roof latches being overtightened some over the years. The rest of the roof is slightly convex (which I think is intentional?), but those were visibly bent a little near each latch attachment point. I cut them out with a death wheel and temporarily secured the new 8' sections with some 1/16" thick aluminum angles. I just clamped it all and ran a few self tapping screws through it to hold everything together. Hopefully next week or so I can take it over to the shop and have the welds touched up!
Here is a question about jacks and jack mounting - most rigs I see have corner jacks bolted to the upper wall of the camper, but I was wondering if anyone uses the old Rieco #1 style brackets anymore...
It seems like you could just leave them permanently bolted to the floor of the "wing" sections and mount or unmount the jacks as needed (the 2 that came with our camper just mount to the jack using 2 huge bolts). Wouldn't this support the weight of the camper way better, since you're loading everything in compression rather than relying on the connection between the floorpack and aluminum frame to take the weight? My only concern is that maybe the connection to the camper (through the #1 bracket) isn't stiff enough to support the camper in the wind, and the whole thing could fall over and destroy the floorpack... Something like this, but just bolt that bracket on permanently...
Okay after some more research I found @Rusty 's build with what looks like my #1 brackets permanently mounted in such a way that the jacks can swing up out of the way for transit!
This seems like a great solution and I might try to copy it... More ground clearance and I could probably reuse the two old tripod jacks that came with the camper - especially if I can figure out how to remove the tripod itself and put some kind of foot down there instead (that would make them slightly less heavy).
