Ruck_and_Roll
Last week installed the BMV-712. Finding it fairly nifty. I ran through each of fixtures and was able to determine their power usage...cool. Turning camper master switch off showed no discharge....cool (nothing mysterious is draining my battery). Plugging into shore power and pulling out master switch shows battery charging....cool.
Everything seemed to be working as expected until I plugged into truck power later in the week (finally got this wired up). Car is on and shows + charging. Everything seems to making sense....Until I turn the truck off.
Now battery monitor is showing
-1.0 amps (when atwood plug is connected)
Now it even gets stranger, I disconnect the atwood plugs and I'm seeing around -0.5 amps. This is consistent. Master power is "off," and/or master power is "on" (and everything is turned off), both show around -0.5 amps. Turned off/on master fuses. Went camping this weekend. Consistent -0.5 amp draw when nothing is powered on and/or master switch is off the whole time.
All the electrical components seem to be stock:
Converter: Iota IDP-30 (no IQ4 or IQ-AGM)
Battery Seperator: Sure Power 1314/1315 (can't tell which model number as it is packed pretty tight)
So needless to say I'm a little confused. Any comment on the following hypotheses?
-Battery monitor itself is using about -0.5 amps (seems unlikely particularly as it showed '0' discharge for the first 3-4 days I had it installed)
-I somehow damaged the battery? Batter is a cheapie. It is a FLA 75AH that came with the camper. He stated it was new. Thursday morning I did notice the propane alarm going off after plugging into shore power. Could the batteries have cooked and somehow become damaged to a slow discharge?
-Other scenario?
I guess there are technically two concerning issues; 1. being that battery is discharging around -0.5 consistently and 2. that the discharge seems to be a little higher when plugged into the truck (and truck is off).
-Other scenario?
