Masonjames
- Joined
- May 17, 2017
- Messages
- 3
I know there are a few threads on this topic. I have read through them all a few times, however I still haven't been able to find much information that address some of my questions/concerns with securing the Alaskan. And the net is stocked full of a million different opinions when it come to TC's.
Camper is 64 or 65 NCO. Completely rebuilt so is structurally sound. Truck is a 1995 Ford F-250 regular cab long box. Camper to be perementaly left on truck so don't need to worry about ease of loading, unloading.
The truck and camper will be used mostly for off highway use. Backcountry camping, fishing, hunting. No extreme off-roading, but rough service roads, random dirt roads in the hills etc.
I want to use the bolt down method to secure the camper to the truck. Don't want to use happijacks, torklifts, turnbuckles etc, if at all possible. My only concern (i blame the internet) with any mounting method, most specifically the bolt down method is chassis flex and wether I'm going to start tearing my camper apart by using it as I intend to. Apparently these 90,s Fords have some major frame flex. This is my first camper. So I have no experience and limited knowledge with using TC's.
So I'm hoping some people can share some real world experience they have had with theirs or others makes, using the bolt down method or who have abandoned the bolt down method and offer me some direction and advice. Especially welcome if you use them off the beaten path.
Questions
Is bolting directly to the bed any benefit or disadvantage over bolting directly to the frame? Or to the bed cross members?
And would bolting to the frame increase the amount of forces applied to the camper from chassis flex over bolting to the bed, or should it be someone equal since the bed is bolted to the frame.
Where is the ideal location for bolting. While considering and trying to lessen the impact of chassis flex.
All 4 corners? Or bolts more centeral and further away from corners?
Would 3 bolts, 2 front 1 back, or 1 front 2 back be any benefit over 4? since I assume 3 points can flex more then 4.
Would leaving the bolts a touch loose help the camper move/give a bit rather then flex a bunch? Or would this just start to destroy the bolting area, camper and truck.
Additionally can I also lightly bolt the overhang to the top of the truck bed wall? With the proper spaced shim in between, and reinforced.
Thanks in advance.
Questions
Thanks in advance.
