Thanks for the reply Stan. I guess I'm a little confused now. When you say ground the Aux to the frame, are you refering to the ground that's coming from the truck(which is already in the duplex wire} or does that mean a new ground bolted to the frame from the camper? Will that mean I will need to connect and disconnect a ground everytime you slide the camper into the truck? The image you sent looks like your 10 2 stranded comes in on the passenger side. Also, is the battery for that set up just in front of that bench space? Lastly, am I to assume the campers aluminium skeletal frame is not a "bombproof" ground.
Longboardcr
I have a Hawk camper so my picture here should be similar to your camper. This is a picture of the "ground bar" located just in front of the battery separater (Sure Power 1314), under the cabinetry under the monitor panel. The "ground bar" is grounded to the battery separator....so anything you ground via the "ground bar" will be grounded to the frame (chassis).
The duplex wire coming off of the battery separator is the power cord you plug in and unplug from the truck when you install/uninstall the camper. If you follow that wire forward you will find it comes out under the hood next to the battery and is grounded (at least mine is) on the firewall (chassis/frame). The positive wire is attached to a 30 amp breaker, and then continues on to the positive side of the battery.
Here is a picture of the area where the Battery Separator is located...you have to remove the bottom cabinet door....then the screws holding the small wood panel covering the Battery Separator. Beware there is one screw coming in from on top (don't forget that one). Once you have the screws out...just slide out the panel to access the Battery Separator and the "ground bar."
The "ground bar" is grounded to the battery separator. When you plug/unplug the cord from the truck you are connecting/disconnecting the positive 12 volt power and the ground (chassis/frame). The "bomb proof" ground for the camper would be the "ground bar." You will see that there are many unsued grounds available from the "ground bar."
Hope this makes sense.
