Awning Alternartive
Old Crow - Thanks for the info. A little small at 6x6 but worth considering since it looks simple to set up.
We use a 10x10 qwick-shade style shelter. Fits over a picnic table and is waterproof. It's big and heavy but sets up in a couple minutes.
Bseek said:
This is the one I plan to purchase eventually. So far I haven't needed an awning. Moving each day and easy set up were the key factors in my decision to get an ATC.
http://www.busdepot.com/details/awning/
I just ordered the 8x8 foot version. Looks like I will have to do some modding to make it work but I think it will do the trick, especially if I rig it to swap easily from side to side.
My cheap awning was fairly successful. It was pretty windy this past weekend on the White Mountains. Other than the telescoping poles all the parts can be found at most hardware stores. I want to get a second set of tarp poles in order to keep it horizontal instead of slanted down. Also want to find a 6x20 tarp to extend it further out for more shade. The reason I use a 6' wide tarp is because that is the width between my jack mounts. For wider/longer campers you can have a larger tarp. Really happy with this as of now. The true test will be in Death Valley where the "W" thing can be fierce.
This is the type of tent/tarp pole I used:
https://smile.amazon...d=ATVPDKIKX0DER
I'm thinking about getting a set of these since they are lighter and have less chance of corrosion.
http://www.walmart.c...-8.2FT/53728954
