Best year range alaskan camper?
pbotz
Jun 10, 2017
15
Hi All
I have been searching for a pop up camper for my truck. I originally was set on trying to find a used FWC Grandby, however the more I research Alaskan Campers the more I want one! I have skimmed through all of the 450+ topics on this forum and have learned a lot of great information. However, I was wondering if there are some golden years that are particularly desirable. I can't afford anything new, and this is also my first truck camper so I really don't want to spend too much money. I have looked and spoke with a couple people selling Alaskans. One is 77', the other and 88' and the last a 94'. Did the quality of materials change through the years? Are the older ones more desirable? I have read that certain campers were made in Amish country and their attention to detail is superb. The campers are all similar in functionality and options. Obviously their are much more important things to look at such as damage, water intrusion, wood rot, mold, etc., however if all campers were maintained equally well, is there a golden era that is particularly desirable due to quality build and materials? Any help would be greatly appreciated!
Peter
from its inception in the late 50's through the mid to late 70's Alaskans were built with pine and fir framing, plywood interiors most frequently white ash skins. In the late 70's (get the exact date from Brian at Alaskan) they tried to "value engineer" the interiors with flakeboard with photo skin finish....that was done through the 80's...in the mid to late 90's they went back to plywood with ash skins. If the 80's campers got damp in any way...they tend to peel their finish off of the interior...it gets ugly quickly
there were several builders and some used Birch or maple ply but those are few and far between....the plumbing also varies slightly from access points and drain locations....some had porta potties installed some did not, some had propane tanks installed and some did not...it's all good...modifications abound depending on the user
the late 90's were built well but you rarely find them for sale...most of the time it's some form of neglect which has caused water intrusion and damages vary in extent.
I'm most fond of the Ash plywood finish...probably because i'm a wood guy....alot of cabinets and furniture in my background.
There are still many out there...hidden in someones barn...maybe with exterior damage maybe a minor crash or two....it happens....low hanging branches in campgrounds have taken their toll to be sure
repairs can be extensive or minor...depending on how much of a perfectionist you are...ask Ripper....(;>)...keep your skill level in mind...but always remember....It's still a camper...made to camp and enjoy....don't get so involved that it becomes a museum piece...use it, fish with it, raise kids with it, have fun
Welcome to the addiction Peter..... ;)
Wow, thanks Rusty for the reply on that!
I was honing in on the 88' but from what it sounds like it may not be the best quality workmanship. The seller seemed to have taken immaculate care of it, but the quality of materials is definitely a consideration. It is a 10' CO, which I really like, so I guess it just depends if the price is right.
The other one is a 77', and although I haven't spoke to the owner yet, but I will definitely ask him about the material. I would hope he would be able to tell me if it is plywood or particle board. I figure with what my needs are, I really just want a roof over my head with a heater should things get cold... I have a one year old and my plan is to have us camp, not "glamp". I feel like unfortunately the FWCs and Airstreams are so trendy these days and command such a premium, but I just want a decently priced truck camper that is simple but has good bones that I could build upon.
Thanks for the welcome Rusty, your input is appreciated!
don't worry about a heater...unless you plan on winter camping...and even then.....an extra blanket (wool) does the trick
many of the vinyl faced particle board interiors are dark and have raised panel doors....you'll see that....go and look at them...watch for water staining patterns, dark screw locations and darkened corners
sometimes simple finger pressure will expose weak points...to an owners dismay
best of luck....would that 88' be in West Marin?
Hi Rusty
Yes the 88 is in West Marin. Talked to the owner it sounds like he took good care of it. But it does have the vinyl pressboard which isn't the best. Has new jacks, new pirelli strip. But the price seems a little high. Any thoughts on it?
price is high for the year and the interior...jacks are nearly 750 new and pirelli is 100 just for the material.....all these considerations....
and you have local competition for Alaskans as well
https://saltlakecity.craigslist.org/rvs/6162557742.html
Hi Rusty
This is the camper I am actually honing in on. The PO did quite a bit of work. It still needs a few things like:
-water tank
-CO cushions
-interior siding on pop up part.
-some holes in the skin need to be repaired.
I talked with the Current owner for about an hour yesterday. Obviously not perfect, but not particle board interior either. This is more in my price range. Is the price fair?
I was looking at this unit on eBay as well. More work involved it looks like but also of the vintage that is more desirable.
https://www.ebay.com/itm/172726297092
the one in salt lake city is the better deal from what I can see of the unit...the other one has some staining...not rot staining but wet none the less...and all over staining as well
fair price on the one in Salt Lake...a little work to be done but that's the way most come...clean interior from what one can make out
the jacks on the salt lake camper are hydraulic and have a modified bracket which is easily converted to full electric...
the refer is vented into the interior...see the refer pic and the vent above the unit...good one to modify for exterior venting
I've checked out the ads for all three...I live 15 miles from the West Marin one but it is a bit expensive. The Missouri one has some damage in the upper front corner which can probably be stopped with resealing the drip edge without replacing the panels. The SLC one is missing some interior panels to the left & right of the window in the photos I believe. The West Marin looks to have been parked out of the elements as the paint looks perfect on the outside photos...the Missouri one has minimal issues but who knows....the SLC needs a bit of TLC. I'm not interested in the West Marin (too expensive and too big) and the others are too far to drive to check out only to find they aren't what I want anyway.
All three are 10' AKs and I am determined to find myself an 8' CO AK so I have not contacted the owners. Good Luck with your hunt! I will say this; after watching the WTW and CL since December....these three are very good examples if the cost and location work for you!
Hi Rusty
The Salt lake owner stated that he has done some modifications to the jacks to allow the front to be modulated as he stated the fronts are a little heavier and have tendency to bind. I am not sure how he did that but he said with several valves??? That would be really cool to put an electric system on it. I do see the rectangular vent above the refrig, is that what you are talking about? If I get it I would love to know how to vent that to the outside...seems like a safety issue to me for a propane refrig.... Thanks for the tips you are awesome!
Peter
Hi PackRat
Thanks for your reply. I would say if you live 15 miles away from the one in West Marin you should check it out! I live in southern cal and there isn't one nearby anywhere.... I honestly can't believe how hard these are to come by. I have spoke to both the owners and the West Marin owner stated he wouldn't budge on price, that one however looks to be in pristine condition so maybe the reason for the high price. It would be a 6 hour drive for me and a 10 hour drive to Utah so all your feedback is invaluable. Did you find more results in your search in December? Obviously now is not the time people usually sell their campers. I don't mind on the 10 or 8 ft I really just want a CO. I do like though how the 10 has a side dinette so I can put a crib down that wouldn't have to be stepped over on but really not that big of a deal. I hope you find one that suits you! 6 months of searching can be daunting....
I believe the salt lake owner is talking about the hydraulic cylinders inside the camper....it's common to add valves to equally distribute the pressure on all 4 uniformly...
I was talking about the exterior hydraulic jacks and the mod to the bracket to accommodate their use
I believe the one in salt lake is a 8'CO.....
Thanks again for the info. The exterior jacks are not much of a concern to me. I was planning on leaving it on my truck and bolting it to the bed, which seems to work fairly well from what I have read.
pbotz.....check the Albuquerque Craigslist under "Alaskan Camper" or "Alaskan pop up" that one is in the desert and that's where the problem with rotting is less than where it rains a lot.
It is a 8 foot CO and looks in pretty good condition and the price is right....it's just a bit too far for me right now.
FYI, the quality vs year rule is more like a fuzzy guideline. Mine 8' CO was an '84, but was all ash and ply, with some solid pine. No flake board, and only a single piece of Masonite as a cabinet divider
...which is only part of why the older AK prices are all over the place....
Condition exterior
Condition interior
Interior stains (a hint towards leaking)
Accoutrements ( oven, ice-box vs 2-way fridge)
Front dinette/bed vs side dinette/bed
Toilette
on Craigslist There is a nice 1996 10 co for sale in Victor Idaho for 10.000. Looks to be in excellent cond. Wish I was ready I would check it out but I still have to wait till end of the year.
Well guys I have spoke to the owner in Utah for about two hours now and decided that I am gonna make the trek up there this week. It needs a few things like:
-Paneling that was removed due to rot
-Insulation
-Door latch not quite lining up on the top door
-Small leak in the faucet that is from a pressurized water source
-Some exterior marking and clearance lights need to be replaced
-New water tank
-New mattress in cab over part
-Blinds on side windows
BUT.....for the money it seems to be a fair buy. PackRat, I did see the AK in Albequerque, that one looks to be in pretty good shape, at least the emblem was super clean. I just don't quite know if I want to spend that much money on my 1st AK. I kinda find that funny because people probably spend more money on awnings than this one is listed for.
The owner states that I could go camp in it today, and I believe it. I don't need anything "new", and it is perfect for me, my wife, and my 1 year old. Thanks again for all the advice, I will no doubt be here again on the forum looking for more!
Peter
Mine looked identical to the Utah camper when I got it. Give it a real good look see for rot. I would assume the owner separated the upper and lower section to do the repairs, so hopefully he got all the rot. Replacing that paneling and the other repairs listed are easy, except possibly the door alignment. It would be awesome if the owner had pics of the inside of the upper section when it was off.
2000 is cheap if that's all it needs. I spent 2 grand on mine, then spend another 10 grand and 3 years trying to make a new one( I may need mental help :) )
Good luck, don't wait too long, it may disappear , and all that work on the upper section is lots of manhours
Keith
