Camper jacks
Jbriscoe
Sep 4, 2014
1
Anyone put regular camper jacks on an alaskan? The old school kind on all four corners? I'm tired of the instability of the tripod type.
i did. the jacks help me a lot when i'm loading it by myself. i have dropped the back end of the camper 8 inches onto the bed of the truck before while using the two jack system. scarry!!!!! i don't leave them on when they are on the truck. i had some brackets made by my local metal fabricating outfit.i think the jacks cost me 75 bucks on craigslist., and brackets about the same. just two bolts on each jack and they come off. i have the two cable crank jacks and two sets of 4 screw type jacks if anyone wants them. the screw type don't go high enough for my truck.
wes
whichever way you go for brand of jack....never use only 2...3 is scary enough.....
always...ALWAYS use 4 jacks...one at each corner...or close to the corner ;)
I like the idea of using corner jacks. I have been using two cable jacks and two screw tripod type jacks and have never felt very comfortable with the process.It also leaves wrinkles in the camper sides. I have 4 screw type camper jacks left over from my four wheel and am going to construct some corner brackets that won't interfere with the top going up and down. It would be great to have them easily removable. I used wing nuts on my four wheel to facilitate their removal. The question is how to have a vertical flange to clamp the jacks to without interfering with the top lowering. If I find absolution I will post it.
Manfred65 said:
one thought on any camper: saves weight and reduces the risk to crash the jacks somewhere:
How to release and mount 4 camper jacks in seconds. The german FWC-Importer has a Patent now for a change system
called D-Jacker:
http://picasaweb.google.com/PickupCamper/D_Jacker_for_use_with_Rieco_Titan_Jacks#
Those brackets would not work on an Alaskan as they would mount on the corners of the upper section, That when jacked would put all the lifting force on the upper section causing the upper and lower section to seperate. You need to lift the alaskan from under the undersection.
if you look closely at my pics in previous post, you'll see that the jacks are connected to the vertical flange. that flange unbolts from the horizontal bracket ,but stays attached to jack. the horizontal bracket is attached to the camper's bottom half. the bracket sits 3" out from the lower half to let the upper half clear when down. the brackets are made of 1/4 inch steel. if i had it to do again, i would have the bracket continue down the side of the camper more to limit the amount of flexing the bottom 1/2 does when raising one jack at a time. i just have to do small increments per corner when raising. in the third pic, you can see one of the two nuts(silver color) to unscrew to separate the two pieces of bracket. the other one is on other side of vertical flange.this setup doesn't leave wrinkles in the skin like the old bracket directly behind(grey color) in the third pic and in front of black bracket in 2nd pic.
hope this help. this system works good for me.
wes
