Can I mount gas lifting struts with the gutter
Black914
Mar 17, 2024
38
Colorado
Just wondering if anyone has been able to install struts with the gutter inpace? Don't mind drilling through it but I really don't want to remove it. I spoke to Brenda at FWC and she didn't think their kit would work in the back. Sent her pix but haven't heard back yet. May not need them since I have ordered a speaker stand.
If you use the right strut brackets I think it's not a problem.
Don't know which ones to recommend as there are a few different ones.
I installed a gutter above the door on my Bobcat and I installed struts.
Since the bottom strut brackets are centered together you could remove the gutter add the brackets then cut a notch in the gutter to fit around the brackets.
If this method works remember to give the bracket area a good amount of sealant.
