ceiling sagging in four wheel camper
mtnras
Mar 30, 2011
35
The interior ceiling of my four wheel camper grandby ~2002 is sagging. the molding that holds the interior ceiling padding up keeps popping out. initially i was able to just tack it back in place, using the original tacks, using a rubber mallet and it would hold for weeks. No longer the case!
Any suggestions on how to repair this?
m
Small screws. The aluminum is thin. Using my Dewalt driver a small screw goes right in.
thanks. that was my thought. just tough to believe that the tacks were going through aluminum and not wood.
m
Have the same issue here, I haven't figured a way to stretch the fabric far enough to glue/silicon to track, any thoughts ?
I opened a section of my ceiling to install solar feed wires at the fabric seam To reinstall I used 3M 90 contact glue on the aluminum and fabric Using 2 coats I was surprised how well it held while stretched tight
I used smallish screws from piano hinge w pilot hole and countersink to hold moulding in place. It's held for the last 2 years and looks factory
