Craig, as long as I've been running around on snowy mountain roads in California, these have been the designations/requirements -
What are the R-1, R-2 conditions that I hear about?
Although Caltrans does not post signs with these designations nor use them to announce chain controls to the public, they are used internally within Caltrans and the CHP as a kind of shorthand to describe chain restrictions and may be included in traffic reports disseminated by various news outlets.
There are three primary categories of chain restrictions, as shown below:
Requirement 1 (R-1): Chains are required on all vehicles except passenger vehicles and
light-duty trucks under 6,000 pounds gross weight and equipped with snow tires on at least two drive wheels. Chains must be carried by vehicles using snow tires. All vehicles towing trailers must have chains on one drive axle. Trailers with brakes must have chains on at least one axle.
Requirement 2 (R-2): Chains are required on all vehicles except
four-wheel-drive vehicles under 6,500 pounds gross weight and equipped with snow tires on all four wheels. Chains for one set of drive wheels must be carried by four wheel-drive vehicles using snow tires.
Requirement 3 (R-3): Chains are required on all vehicles without exception.
R-1 and R-2 are the most common conditions. A highway will often be closed before an R-3 condition is imposed. Some local areas may use variations of these designations. You must follow the directions on the signs posted for chain controls or any instructions given by Caltrans or CHP personnel at chain control check points, even if these are at variance with broadcast road condition reports or information contained herein.
Under truck requirements I found this -
There is no exemption for heavy-duty commercial vehicles (
over 6,500 pounds gross weight) equipped with snow tires. Chains must be installed on heavy-duty commercial vehicles whenever chain controls are posted.
Source -
https://dot.ca.gov/travel/winter-driving-tips/chain-requirements
We needed to know and follow the requirements when we responded to SAR incidents - always in storms. It was another thing for us to be religious about. Our people had all sizes of trucks and equipment and we all had to legally get through together so we could get to work. Agencies that we represented appreciated us not becoming an issue while in route.
We are occasionally asked our weight when traveling. I know a lot of people - especially as they buy bigger and bigger trucks - are unaware of the weight requirements.
The wind can sure blow in the Mono Basin, can't it?
