and this made a difference? strange. can you trace/see the wires to confirm there is nothing else in the circuit path?
It definitely made a difference. Not sure why. Unfortunately, I can't trace the wires behind the cabinet. There's an area from the camper battery to the separator I can't see. Electrically, it probably shouldn't have made a difference...but I can tell you for certain that when I removed ALL wires from the separator (i.e., after I disconnected the engine battery from the separator) and took it completely out of the equation, the controller behaved differently.Vic Harder said:and this made a difference? strange. can you trace/see the wires to confirm there is nothing else in the circuit path?
.radarcontact said:Anyone still reading this blog....I solved my problem today, finally....over a month of frustration. And the solution, as you would expect, was simple. ......
So, I ran over to NAPA and bought a heavy gauge (4 AWG) battery wire, 12 in long. Couldn't be that simple, right? Well, call me a dumbass for screwing around w/this over the last month or so and not thinking about the gauge of that wire, because, as soon as I installed it and reconnected everything, it worked like it should.
Want to thank everyone who pushed me to pay more attention to the BATTERIES....should have listened to you guys. When in series, use a heavy gauge wire to connect the batteries. Lesson learned LOL.
I like this theory.pvstoy said:If the gauge is too thin then it would have a problem for those big 6 volt batteries talking to each other in series That would delay the flow and the controller would see one voltage and then as the battery's equalize the controller would see different voltage. And perhaps is where your endless cycle loop was created.
When you replaced the wire, you disconnected that battery power from the system. Seems to me that this has happened before, no? Disconnect and it works fine for a bit?radarcontact said:Well, as the saying goes, if it's too good to be true....
Pulled camper out of garage this AM, and it went back to its cycling thing.
Hard to figure, as yesterday it performed flawlessly for hours after I replaced that wire. I changed settings in the controller on the fly, it responded perfectly. No problems. Today, back to square one.
Has to be 1)a battery is bad, though they both checked out fine, or 2) the controller just doesn't like dealing with 2 6V batts in series.
radarcontact said:Final update on this thread, for anyone interested....
Was in S. California this past week camping on the beach, and I stopped by Blue Sky in Vista and spoke with Ryan, the head techie I've been dealing with. We went into his lab and set up conditions that replicated my camper setup. Initially, we weren't able to repeat my results. After stressing that my controller acted up when my batteries were fully charged (i.e., 100+%), we applied a charge to his test battery which took the voltage up to a full charge, then connected PV input. The controller did exactly what mine does, cycled between absorption and float continuously. Ryan is certain it's a firmware issue, and will have his software engineer correct the coding. Once that's done they're going to send me an updated controller.
Happy ending, and glad to find out I wasn't losing my mind LOL. Blue Sky is happy I've helped them improve their product. Their customer support is outstanding, and I wouldn't hesitate to purchase products from them in the future.
Happy Thanksgiving!
Vic Harder said:Awesome news. I second rando's question. A recall notice would be the "right thing" to do.
Can't say for sure, but thinking they will fix the problem for anyone who's experiencing it. They have 3 controllers they market, and as far as I can tell, only my model (SB3000i) has the performance issue. We hooked up their lower end model while I was in CA, and, interestingly, it performed fine under the same test conditions. So, the coding issue is probably unique to the 3000i.rando said:Glad you got it figured out, and happy that it was a problem with the charge controller, and not your set up. While BlueSky will likely make this right in the end - it is a bit worrying that they seem to have a major firmware bug and that it caused you so much work. I wonder if they will issue a recall on all controllers with this version of the firmware, or just hope most users don't notice?
