alano
I'm in the process of adding a remote panel in addition to the 2 flexible panels already glued to the top of the camper. I'm parked in mostly shade beside the house and I wanted a base line of what kind of amps are feeding into the batteries so I checked the charge controller and was disappointed to find only 4.1 amps at 12.8 V (been running the fridge and it was quite hot yesterday).
I've had wiring trouble that I thought I fixed so I got my amp-meter out and both panels were pumping out about 2 amps. I noticed that the panels were pretty dusty and had an artistic amount of guano applied so I brushed them off and then rinsed them with plain water using a Handiwipe. Checked the meter again and found 4.5 - 4.4 amps. That's almost 10% improvement. Of course atmospheric conditions might have played a part and I'll have to wait a while to repeat but I wonder if others have cleaned their panels and noted an improvement in performance.
Alan
Alan
