No it does not. Bamboo cloth cover all around.rubberlegs said:Vic, does your mattress have a vinyl bottom cover? I'm thinking not, since it would block the moisture flow into the hypervent.
Not a lot. On that last trip I mentioned, daytime temps were above freezing, and night time temps were around -10*C. At that temp, even with just two windows open the slightest amount the furnace seems to run way too often, and that's with the inside temp set to 45*F.craig333 said:I'd love to see just how much ventilation everyone is running. I suspect its just a crack and or not using lower and upper ventilation. Or maybe I'm just genetically disposed to exhale little moisture
