Although the Engel is more expensive than the ARB, the option to add the two zone, may be worth it. I've read you can run the lower part on freezer and the two zone as a cooler. Regardless, the option of keeping your groceries on the bottom and beverages on top sounds pretty good. Also if you need more space in the future at least there's the option with Engel.
Or does the two zone fit the ARB or others, or do the otehr brands have their own two zone? Haven't been able to find one. thanks.
