Regulator23
Has anyone installed an external GFI plug on their rig? I have a 2018 Grandby model and could see a benefit to having this. If so, where did you wire it from and where did you install the plug? Thank you
Thanks, I didn’t like the idea of putting holes in the camper either. Are you running your inverter off your truck battery?Vic Harder said:My inverter has 120v GFI outlets, and I used a contractor grade 12g extension cord to run power to the outlets, including one on the outside. I've only ever made holes in the camper when I could see the framing because I had the inner walls off.
That was my first thought. I use the drivers side turnbuckle door for my portable ac vent ( we live in South FL…hot) but the passenger side might work. Thanks for the thought.rubberlegs said:A thread that was similar had suggestions to route an extension cord through the turnbuckle doors.
Got it. I appreciate your input on this as well as other things you’ve helped me with. This is the first truck camper rodeo for us and we bought a, like new, 2018 Grandby model. Our home base is south FL so the first thing I did was a portable AC. Now I need to ‘beef up’ the battery/solar system (which you gave me great thoughts there already), install an awning ( which I found mounts that bolt to the jacks so I may just go that route as opposed to trying to find the studs and through bolt to them) and some other storage type things. We’re planning a trip up to the Arctic Ocean in early August and have several short trips prior to that to get everything ironed out.Vic Harder said:No, the inverter runs off of the dual BattleBorn LiFePo4 batteries in the camper. 3000W Pure sine wave, AIMS brand. It runs our induction cooktop.
What kind of truck are you using for your Arctic trip?Regulator23 said:Got it. I appreciate your input on this as well as other things you’ve helped me with. This is the first truck camper rodeo for us and we bought a, like new, 2018 Grandby model. Our home base is south FL so the first thing I did was a portable AC. Now I need to ‘beef up’ the battery/solar system (which you gave me great thoughts there already), install an awning ( which I found mounts that bolt to the jacks so I may just go that route as opposed to trying to find the studs and through bolt to them) and some other storage type things. We’re planning a trip up to the Arctic Ocean in early August and have several short trips prior to that to get everything ironed out.
Probably not a bad idea. We’ve van camped (E350 extended cargo with a 6.8L V10) for the last 10 years and taken some long trips, but the FWC is quite a step up (we can stand in it!!) I’ve got a Ford F350 with the 6.7 diesel. It has 4WD and seems pretty durable.Jon R said:What kind of truck are you using for your Arctic trip?
You might want to start a new thread: “I’m headed to the Arctic Ocean from Florida in my new camper after only having taken a few short camping trips. What should I bring? What should I leave at home?”
First thoughts? Bug spray and fuel money. Bring lots of both.
