Falcon shell weight
Skeeter
Jan 4, 2009
187
WA and AZ
How much does a "Falcon" shell weigh with only a furnace as an option? Looking at one that claims to be 360 lbs and the FWC website says shells are between 530 and 590. Does anyone have any info? Thanks-
Yes, it is pretty small. It would work out just right for me due to the small engine in my Ford Ranger. There is a small plate just to the bottom right side of the door. It had a registered weight of 360. A little confusing. This camper is registered in Washington, wondering if that is the reason the plate was there.
The Falcon Shell Model with a furnace and propane tank in probably closer to 550 - 600 lbs.
The State of Washington probably put a number on the camper just for their records (gusstimate kind of thing).
hope this helps
