Finding propane leak?
Goat
Nov 25, 2015
7
I own a 2016 FWC Hawk that I bought used two years ago. I have struggled since then to find the source of a propane smell which seems to be getting worse.
I have checked the tanks and hoses in the tank storage area by using the typical soapy water approach but cannot find a leak. I had my AGM batteries checked last year after reading through threads related to propane smell that suggested this could be the cause but both batteries checked out fine.
I have avoided using my three-way fridge for anything but an icebox thinking that perhaps it was the culprit but I was using the camper over the past few days and while sleeping with only the heater going, the smell got bad again and triggered the carbon monoxide detector. This happened twice over the course of the night so I turned off the heater/propane.
Do you have any pointers on other ways to troubleshoot and find the problem? I've got a month-long trip coming up in a few months (assuming we can leave our houses by then!) and would love to have this figured out. Thanks much for any help/advice you can offer!
can you get at the connectors for the heater and/or fridge? Those might be leaking. ANY joint in the propane lines is suspect too.
I haven't used one and don't know how well they work, but you can buy inexpensive (~$25) gas sniffers intended for finding leaks. They usually have them in stock at building supply stores like Home Depot. That might help you narrow down the area of the leak.
Thanks Vic and NRVhawk. I ordered a gas sniffer and will be digging in to see if I can track down the leak. I'll circle back in a week once I get the probe and let you know how it goes!
I had propane smell outside that ended up coming from my stove connections that had been beat up pretty bad from 13 years of off roading. But instead of smelling up the inside of the camper; since the stove top was down all the time except when the burners were lit. It was blowing back through the stove connection access and causing me to smell it outside. It was cheaper to buy a new stove top than to replace all the o-rings and connectors for 2 burners.
Thanks for the past input. I finally tracked down a sniffer and found the leak. It’s coming from the lower left hand corner on hot water heater which is accessible from the outside of the camper. I have attached images including a close up of the connection. Should this fitting connection have teflon tape? I would assume not since its a compression fitting. I will take it apart and see what I can figure out but welcome any thoughts.
The flare fitting where the copper tubing connects requires no teflon tape, however the pipe threads on the other end of the 90 should have teflon tape or a paste type sealer applied. Use a soap solution after you repair the leak to check it.
And make sure you use the orange teflon tape, which is thicker than the white stuff used for water pipes.
Our gas supplier has leak testers that they loan out. Much more sensitive than the cheap ones.
