Fleet Bottom Slats
huckfinn
Dec 25, 2014
48
My Fleet has been happy in the bed of my Tacoma for a few years. When my wife wanted dirt for the garden, all I could do was shrug. Also, my driveway is so short and steep and warped, when I did attempt to perform a camperectomy, I managed to knock off a couple of the slats under the camper.
Never again—not in the driveway, anyway. The street we are on is not as steep and is at least true so I just need to build a dolly to move the camper back and forth, and with the help of my truck's winch, I think I can do it. However, with much angst, I did get the camper off in the driveway.
Now I need to replace the slats. Each slat is 1-1/2", glued and screwed up into the floor above, just a few threads, almost designed to fall off easily. I'm thinking of replacing all the slats with a solid double sheet of pressure-treated plywood glued and screwed and sealed against moisture. The bed of my Tacoma is waffled so I'm not so much worried about water. The weight is something but not enormous. The double-sheet, with chamfered edges, will have fewer corners to snag the guide brackets bolted into the truck bed. Why shouldn't I do this?
Thanks—
Mark
For me it would be about the extra weight.
when I had to build up the bottom of my old pastime to get it to clear the cab, I used cedar 2"×4"s
they are very light and super weather resistant
Maybe they would work well for your situation also.
That is a great idea smlobx. If I ever take my flatbed off I would definitely replace the wood with foam. I had thought about filling in the spaces between the slats with foam, but entirely replacing the slats with foam would be an even better idea.
The compressive strength on the foam suggested is 15 PSI. The bottom of my fleet is ~ 72"x72" - so ~5000 sq inches, which means the foam can take a ~75,000 lb load before compressing. It is not quite that simple in a truck bed with ridges, but you can also get the same sort of foam with 100 psi compressive strength, so I think you would be fine.
Squatch said:
I'd be very careful about replacing the skid strips with a foam sheet. The foam has the potential to compress and loosen the turnbuckles.
Squatch I understand your concern. I guess it depends on how rough you are on your rig. As a point of reference we use a slightly higher density foam board
http://www.homedepot.com/p/Owens-Corning-FOAMULAR-250-2-in-x-48-in-x-8-ft-R-10-Scored-Squared-Edge-Insulation-Sheathing-52DD/202085962
Under weight bearing slabs in home construction that support literally tons of weight. So this is also an option...
Stay away from pressure treat wood. Fasteners will be eaten away, even stainless. Use a 1 X non-treated and paint them before installing, with glue and screws.
Thanks all.
When I called FWC Repair in Woodland, I was advised to replace the slats that had come off, maybe with a chamfer to make them less likely to snag the brackets in the bed. The slats are marine plywood like the floor. I was told that any material that would absorb water (like pt plywood) would hold moisture and eventually rot the floor, even the marine plywood. They'd seen it several times—he said replacing an entire floor costs half the price of a new camper.
Keep everything well painted. Cheap insurance. I just repainted mine this spring. Latex porch enamel works well and isn't expensive. I was going to use a DIY bed liner but cheaped out. My camper is 5 years old and the original paint has held up well. So I went the same route.
Hi longhorn1
Not saying to use pressure treated, but was curious about the lumber destroying the fasteners. Don't they construct patio decks out of this material? I think deck screws are used to fasten the lumber together. I don't really have any experience with PT lumber.
Thanks Russ
Russ, about 10 years ago the treated wood used had chemicals that became illegal. High rates of cancer causing chemicals were found on playgrounds (in the lumber). The new treated wood chemicals desolved the fasteners. As a building envelope consultant I investigated roof failures caused by failure of the wood blocking fasteners. It didn't matter whether the fasteners were galvanized or stainless. They were destroyed. Metal roof decks that had wood blocking fastened to were eaten through. The roofing industry called for the ban of treated wood in all roof assemblies. jd
