Fleet on a tundra
Regular 2x4 had hanging around. The 2x6 on the side is not structure. Just a skirt for looks. Painted white to match camper
Sent from my XT1254 using Wander The West mobile app
Thanks again for your build info and clear pics. One final simple question: is your build a platform that the camper rests on or is it attached as a permanent structure to the camper base?
Sent from my iPhone using Wander The Western city of
Brent
On your Torklift front turnbuckles, how many inches did you cut? Since we both have gen 2 Tundras and 5" platforms thought your mods would be same for me. Thanks again
Not sure if this went thru but about 5 inches. Just make sure there is enough to be strong but not bottom out
Is that like 2.5" on top and 2.5" on
bottom of turnbuckle = 5.0"?
No on the threaded side I cut 5 inches off. I did find one piece of paper from order. It is a happijac. Here is the part numbers
Here is part cut off. Actually more like 8 inches
Here is best I can do with camper on
These are about twice + size of original buckles
Brent
Thanks for your pics and detail.
Sure let me know how it turns out
I am about to put a fleet in my 2009 2nd gen tundra. My platform is already built but I had planned to put it on top of my plastic bedliner. Do I need to remove the bedliner or our others successfully running this setup with the plastic bedliner in place? I know FWC says to remove them first.
